power seat track repair
St. Jude Donor '05-'06
Started the tear down and found the forward gear retainer split just like pcolt94's link showed his was. That is the cause of my "rocking chair" I ordered some "weld on" glue to try and fix it. I will be taking a good gear out of the seat track that the forward and back does not work on to replace this one but will resuse the repaired gear on my passenger side track. Here is a detailed description of the glue I am using on it.
SUBSTRATE RECOMMENDATIONS
WELD-ON 16 is especially formulated to bond acrylic plastic. It can also be used for bonding styrene,
butyrate, PVC and polycarbonate, as well as other plastics and porous surfaces.
BONDING RECOMMENDATIONS
WELD-ON 16 is recommended as an excellent general purpose, high strength acrylic cement. It is especially
useful where fast cure and high strength are desired for applications such as large housings, signs, plastic
letters, industrial fabrications, display items, lenses and models.
GENERAL DESCRIPTION
WELD-ON 16 is a very high strength, clear, medium bodied, fast curing, bodied solvent-type acrylic cement.
Applied to cast, molded or extruded acrylics, it will effect initial bonds within minutes and form strong joints
within hours.This product may be thinned with WELD-ON 3 by approximately 10%. Initial bond forms very
quickly so some parts may be handled within a few minutes of application. Bond strength continues to
develop very rapidly reaching a substantial level within hours. Joints are water and weather resistant and will
generally have similar physical and chemical properties to acrylic plastic.
BOND STRENGTH DATA
The following strength data was obtained with compressive shear loading at 0.05”/min.The materials tested
were ” acrylic lap joints of 1 sq. in. bonding area.
SUBSTRATE MATERIAL 24 HOURS 1 WEEK
Acrylic 1700 PSI 2200 PSI
Polycarbonate 1000 1700
Styrene 900 1700
ADHESIVE PROPERTIES AND CHARACTERISTICS
COLOR: Clear
VISCOSITY: 800 cps
WORKING TIME: 2 – 3 minutes
FIXTURE TIME: 5 – 6 minutes
80% STRENGTH: 16 hours
SPECIFIC GRAVITY: 1.02 ± .040
COVERAGE: 10mil: 28sq. ft./Pint 224 sq. ft./Gallon
20mil: 14sq. ft./Pint 112 sq. ft./Gallon
DIRECTIONS FOR USE
• Parts to be joined should be clean and fit without forcing.
• Apply WELD-ON 16 to one or both surfaces with brush, polyethylene squeeze bottle or gun.
• If cement is applied to one surface, bring the two surfaces in gentle contact for several seconds to
allow the dry surfaces to be softened.
• Assemble with firm pressure while parts are still wet.
• Hold or clamp assembled parts firmly until initial set. Joint strength will increase greatly in 24 hours.
Thereafter, strength will continue to increase gradually for some weeks.
GENERAL DESCRIPTION
BOND STRENGTH DATA
Styrene 900 1700
COLOR: Clear
VISCOSITY: 800 cps
DIRECTIONS FOR USE
Weld on #16 did not work back to the drawing board. The plastic almost feels like nylon. Wish I had a piece to burn so I could use the link I posted to ID it for sure.
OK did some more testing and a burn and am 90% sure it IS nylon. I burned the tip of a gear retainer and it burned blue no smoke and frothed. Nylon is the only one in the chart that froths but I can't get a smell and did not want to let it burn more and risk destroying the cap. I have found a glue call "Plastic Surgery" that is supposed to glue nylon but to be sure I will try using my micro torch and weld the outside after gluing. I will report back........
Thanks for the link pcolt94.
This is my problem and the fix I am using. As you see from the link the 2 pieces seperate. It is nylon. I bought Sure Hold Plastic Surgery glue at Walgreens and glued it back togther. I then found 2 small brass wood screws nd cut the head off. I took the screw and heated it with my micro torch and imbedded into the side away from the tab while continuing to torch the plastic till it starts to burn. It is very hard to see it burning but you will see it bubble and melt and the screw will sink into the nylon. This is to keep the cap end from seperating again. When I reassemble it I am going to use a ball of plumbers epoxy and tuck it in near the end cap to keep it from being able to move. This step may not be necessary but I don't want to do it again. The plumbers epoxy will stick to steel (I hope)and hopefully fill in the void between the cap and the casing. You must be careful with the torch part as I said you may not see it burning and you will have to blow it out once the screw is in position. The nylon congeals back into the same or at least it looks the same as it was before the screw was imbedded.
I still do not have a fix for the worm gear positioner bracket. I have a small crack in the upper tab that I used glue on mine but the rest is in good shape. This is the part that really controls the front and back movement and positions all the gears. It is molded nylon and the micro torch melting and congealing might work on it but as I said my problem was more with the front gear moving so the seat rocks and the retainer fix I have come up with will solve that.
BEZ71 I have not forgot you and will contact you after I do this fix on my other seat as it has the same issue. My pass side seat has an issue with the front/back movement but the up and down is fine so I will be swaping a retainer cap out of it and send you all the bad stuff in it to look at.
My thought was this; I will glue the nylon pieces of the center support back together so that a complete unit is intact. We should then be able to use it as a template to either machine or cast a new one out of aluminum or bronze. Once a properly working example has been made, it should be possible to have it reproduced in quantity.
Ofcourse it will be interesting to see how much that costs.
BEZ71 are you up to making a pilot piece? I'm just north of you in Grayslake, IL. and could bring you the parts.
Here's what we're dealing with:
Hans
Seat Track Transmission
<http://forums.corvetteforum.com/showthread.php?t=2092729&highlight=track +seat>
Mail from Tom today indicates he is working on a plan to offer rebulit transmissions . . . .
i didn't even know a manual track was offered for corvettes? if so, what model years had them and what is the interchangeability of these manual rails?
My power equipment is also giving up, and my thought was to find the needed parts from an RC car vendor (hi-dollar RC stuff), for gears/bearings, etc
Premium Supporting Vendor
Kevin
www.KeenParts.com
800-757-5336
I am getting ready to tear one down. I got 2 tracks with play on the front riser that makes my seat tilt forward or backward with accel or decel. I see the mesh between the bar and outside gear is fine but it does rotate ever so slightly causing this.Anoying it is. I just got a used one and it has a little less play in it so I am using it and going to tear down my old one just for grins and see if there is a way to fix my newer one with a gear out of it. There must be a way to do this if they keep selling rebuilts someone has the gears. Just wish I knew where to get them. Buying a rebuilt is just another corvette tax. They want your core and probably spend 1 hr to rebuild it. Wish I was making $200 an hour.
#33
4th Gear
Rocking Seat
Your walking in my shoes from 2 years ago. I am not the first or leader in this effort. But they got to be getting the parts from some where. We all can repair these things if there were parts. To make one out of aluminum is costly start up costs, need lots of volume. I think you would need a computer controlled cutter to make it worth while. Labor and a machinist is to costly (only government work).
#34
If anything have your son charge double the cost of what it takes to make them & have "us" pay for shipping which should be included in the price.It will be alot cheaper than the alternative($220).I know everyone has to make a living but people are broke.I never seen so many people broke in my life being a Auto tech.Its scary
#35
4th Gear
So, Has anyone made the parts we need for the seat transmission yet? Or, can we buy a rebuilt transmission yet? From what I read in here, glueing and monkeying around with these cheap plastic pieces is not working.
#36
Thanks!
Kevin
www.KeenParts.com
800-757-5336
Keen Parts Blog
#37
Seat Transmission Repair
Here is the deal on these seat transmissions. All the corvette places that are selling rebuilt units are using the same person to rebuild them. They are all sent out. One guy bought the rights from GM and probably owns the molds used to make the plastic part. He refuses to sell the part himself. I refuse to pay $200 just so my seat can go up or down however, it does bother me that something doesn't work on my car so one way or another I will fix it.
#38
BEZ71 PLS let me know if you guys get something done on this. TIA
#39
The parts so far look like they could be made out of delrin so far and would put a bronze bushing in for the shafts to eliminate any precision bores to be machined. Browning and a bunch of other companies make stock gear sets and it seems like a source gm might have used for those parts, it might be worth a look there. I have a very annoying rocking chair seat too so will be interested and have a spare seat track too.
#40
That is what I did. I paid $20 for a passenger side maunal seat track and installed it on the drivers side. It works great!
