Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 12-10-2001, 09:37 PM   #1
black_89_vette
CF Senior Member
black_89_vette's Avatar
Default GM heads part #'s
I bought a 383 crate engine and the whole engine had to be dissassembled due to the fact that the people who put the engine together knew JACK poopie. Anyways, I put my alum. L98 heads on it after they were ported out. So, I have a set of heads here and they have a GM production number stamped into them. Problem is that I don't know what heads these are. They are said to be stage 2 ported, 3 angle valve job heads with this number stamped into them
14102188
Any ideas as to what heads these are? I think my mechanic said they looked like vortec heads.
[Modified by black_89_vette, 7:38 PM 12/10/2001]
black_89_vette is offline   Reply With Quote
Old 12-10-2001, 10:44 PM   #2
DOCTOR J
CF Senior Member
Default Re: GM heads part #'s (black_89_vette)
I'm not sure about stamping numbers - I thought those were production serial numbers put on at the foundry.
GM used to cast the item number into the head - as shown here between the rockers for 5 & 7 cyl (10088113). 113 is the L-98 head casting #.
http://temp.corvetteforum.net/c4/doc...x/car97-11.jpg
drj
DOCTOR J is offline   Reply With Quote
Old 12-10-2001, 10:50 PM   #3
Rich B.
CF Senior Member
Rich B.'s Avatar
Jims' Performance has a Head Chart at -
http://www.jimsperformance.com/headchart.html
...But I don't see your head # there...There's a 14102187, but it's from/for a small-valve 305...
...If that's it, you got ripped... :(
Rich B. is offline   Reply With Quote
Old 12-10-2001, 10:52 PM   #4
black_89_vette
CF Senior Member
Default Re: GM heads part #'s (DOCTOR J)
OOPs, I just rechecked them and the last 3 digits are 183, not 188.
I did go to the gm website and ran the numbers, even the 183 and came up with nothing. I checked it under Chevy, Pontiac and even Buick!
The stamps on the head are..
GM 5
14102183
GOO6 (?)
Old 12-11-2001, 01:43 AM   #5
SunCr
CF Senior Member
Casting # on my original '89 heads is 10088113. I believe the current production I installed had the same number, but it's a different design (the intake manifold bolts are counterbored for a gasket retainer and the rocker studs no longer include the factory guideplates). I recall someone posting info about casting #'s. You might want to try a search under Heads.
SunCr is offline   Reply With Quote
Old 12-11-2001, 01:18 PM   #6
Hendej
CF Senior Member
I put 14102183 into google and got your heads identified as '87-89 5.0 and 5.7L chevrolet/pontiac. See here:
http://www.generalautoparts.com/PDFs/Techtips1.pdf
This also came up:
http://www.nhra.com/tech_specs/engin...ts/CHEV-89.rtf
which says they are 53cc, 11.18 CR heads for a 305 TBI application. None of this is as important as flow numbers, which aren't listed. (IMHO)
Hendej is offline   Reply With Quote
Old 12-11-2001, 09:24 PM   #7
black_89_vette
CF Senior Member
Default Re: GM heads part #'s (Hendej)
Thank you very much for the info. I had a hard time finding any info on them. So, it looks like they're high compression pieces of crap. Thanks for your help Hendej.
Reload this Page GM heads part #'s
Tags
10088113, 14102183, 14102188, 57l, 98, casting, chevy, cylinder, gm, head, heads, numbers, rocker, stud, tpi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
