double din in a c4???
Old 03-27-2008, 10:51 PM
kraftywerkz
kraftywerkz's Avatar
Default double din in a c4???
ok guys ( and or ) gals i want to have installed a double din stereo in my 1995 c4 and do away with the blose system in there but when i checked with crotchfeild they said it will not fit .... but they could not tell me why??? whats the deal with that???? whats too small the stereo or the hole??? i dont wanna hack up my vette for a stereo... ans someone enlighten me???? thanks
Old 03-27-2008, 11:50 PM
Mr. Peabody
Support Corvetteforum!
Mr. Peabody's Avatar
C4 of Year Finalist (appearance mods) 2019
There is a specalized section devoted to cat audio but I suspect that the porblem is that while the opening is high and wide enough the problem is that it is not deep enough by a long shot
Old 03-28-2008, 12:05 AM
WickedVetteLT4
WickedVetteLT4's Avatar
Not deep enough and the hole is din 1/2... not double din.
I wanted to do that but its a pain to make one fit. I have an Alpine IVA D310 flip-out touchscreen im going to run instead because the deck will fit a single din hole...
Old 03-28-2008, 03:55 AM
Hey8You
Hey8You's Avatar
A double din will fit but you will need to enlarge the radio bezel and cut out a plastic support that supported the Bose radio.
Old 03-28-2008, 10:49 AM
WickedVetteLT4
Nice! Did you just trim the stock bezel?
I considered doing the work to make this happen but decided to go single din after thinking about the work involved to make the double din fit. It does look sweet though... hmm... might have to do that now dammit! lol
Old 03-28-2008, 10:50 AM
rickneworleansla
rickneworleansla's Avatar
It can be done it just takes a little customization. I had to open up the console some and then sand and repaint. I'm still finishing it up.
It's tied up with a transmission rebuild at the moment. Hopefully I will have the finished pics in a few weeks.
Old 03-28-2008, 02:00 PM
Hey8You
Hey8You's Avatar
I had to sand the top and bottom on the radio bezel opening a small bit but the sides needed a lot of trimming. It took me about 20 min to modify it.
Old 03-28-2008, 09:58 PM
Gary R
Gary R's Avatar
Circuit City installed a Pioneer AVIC-D3 with just a very little sanding of the plastic and a little change to a mounting backet. They said it was an easy install on my '91.
Gary
To double din in a c4???
Quick Reply: double din in a c4???
