Dana 44 aftermarket gear vendors
Old 03-23-2008, 09:49 PM
purplehayes
purplehayes's Avatar
Default Dana 44 aftermarket gear vendors
Hey, guys I'm installing a dana 44 rear in my 87'. The problem is I need to install a set of gears. I'm looking for some 4:27's, but can't find anyone who may carry them. I was also wondering can i install the gears myself. I have in stalled gears before in other rearends, but the dana 44 look like it might be a little different from what I may be use too. Can the jeep and viper dana 44 gear ratios fit in the vette carriers with out any problems. Can you guys please give me some directions if you can.
Thank you,
purplehayes
Old 03-23-2008, 10:05 PM
STL94LT1
STL94LT1's Avatar
The Viper gears will work.
FYI: Our Super D44's use a larger pinion than a regular D44.
Old 03-23-2008, 11:21 PM
BAM92
BAM92's Avatar
Or http://www.tomsdifferentials.com/tomp.htm
Old 03-24-2008, 05:33 PM
gslotman
gslotman's Avatar
Try these guys - they have the goodies (in the gear ratio your looking for)....4.27 gears
http://www.ikerds.com/merchant2/merc...t_Code=440-000
Old 03-24-2008, 05:36 PM
bruced267
bruced267's Avatar
Toms rear ends
Old 03-24-2008, 11:21 PM
Caboboy
Caboboy's Avatar
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22
'23-'24
An L98 with those gears...........? Yikes
To Dana 44 aftermarket gear vendors
Quick Reply: Dana 44 aftermarket gear vendors
