any hints/tips on using plastigauage tape for rebuild clearances ??
hi there fellas,
just wandering if any one can help advise and give any tips on using Plastiguage tapes when measureing crank and rod bearing clearances please when building engine??
any do,s or donts ??
is it accurate ??
thanks
is it accurate ??
thanks
You lay a strip of plastigauge longitudinally on a dry crank or rod journal, install the cap with bearing insert and then torque the cap to spec. You then remove the cap and read the width of the compressed plastigauge to determine the clearence. The plastigauge package has a ruler like table you lay against the plastigauge that gives you the clearence. Plastigauge works but for real accurate results I use Micrometers and a bore gauge on my race engines.
Larry
Larry
hi larry,
how are ya!
ok thanks for the tips and reply!!
so do you use the green,blue or red plastiguage tape ??,as i have brought all three.
i heard you use the green one ??
i also heard typical oil clearance range is from .001-.0015 ??
thanks
how are ya!
thanks
Just make sure that you lay it down on the crank straight and uniform thickness before you torque down the caps.
It's good enough to get you within a tollerance range.
Larry
Larry
Make sure the Plasticgauge you buy is BRAND NEW prouduction or as close as you can get. That stuff will change it's hardness over time, espc if its exposed to extreme temps one way or the other and that will affect the way it crushes causing not so accurate measurements.
Will
Will
