What is the gear ratio of the performance Axle in a 1994 Corvette?
Old 12-04-2001, 02:17 AM
BlueC4 LT1
BlueC4 LT1's Avatar
Default What is the gear ratio of the performance Axle in a 1994 Corvette?
Hi, I know 2.59's are stock on a 1994 automatic. What would it be with the performance ratio? Thanks
Old 12-04-2001, 03:48 AM
1CanuckVette
1CanuckVette's Avatar
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (BlueC4 LT1)
There is a rumour that they were 3:07's ??? Don't hold me to that but it sounds right. Go in under search and look up some old topics, you'll find it there. :cheers:
Old 12-04-2001, 04:19 AM
Dualnic
Dualnic's Avatar
On my 94 auto i have for RPO:
G44=3.07 Ratio Rear Axle
G92=Preformance Ratio Rear Axle
Old 12-04-2001, 09:05 AM
Springer's LT4
Springer's LT4's Avatar
Cruise-In III Veteran
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Dualnic)
G92 is the performance rear which is 3.07
Old 12-05-2001, 01:33 AM
R23HTC
R23HTC's Avatar
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Springer's 95)
My '94 6sp has RPO GM3 axle rear, 3.45 ratio!
Old 12-05-2001, 01:55 AM
Danger Dave
Danger Dave's Avatar
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (R94 LT 1)
Here are the codes,
GM1 Rear Axle, 2.59 Ratio
GU2 Rear Axle, 2.73 Ratio
GW4 Rear Axle, 3.31 Ratio
G44 Rear Axle, 3.07 Ratio
G92 Rear Axle, Performance Ratio
Old 12-05-2001, 02:15 AM
Ruby_Roadster
Ruby_Roadster's Avatar
So if my RPO list shows GU2 (2.73) and G92 (Performance Rear) - what do I actually have. Is it 2.73 or 3.07 ???
Old 12-05-2001, 02:34 AM
BAdAzZV8
BAdAzZV8's Avatar
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (Ruby_Roadster)
How can I find out what option I had, is it in the VIN somewhere b/c I don't have any of my books or records or anything like that. Or is it stamped on the rear end or something?
Old 12-05-2001, 08:02 AM
R23HTC
R23HTC's Avatar
I may be wrong but maybe a Dana 44 with 2.73 gears?
Old 12-05-2001, 02:56 PM
Springer's LT4
Now this has got my slightly confused... I have the G44 with G92... 3.07 performance rear... but if the G44 is 3.07.. what does the performance rear end give you? :confused:
Old 12-05-2001, 06:34 PM
Danger Dave
Springer,
Try to get ahold of Scorp on this, he can usually be found in the NE section. I bet he know's the answer on this gear ratio situation.
Old 12-06-2001, 11:56 AM
dgoodhue
dgoodhue's Avatar
You are confusing yourself. The G** (in your case G44) is the axle ratio that you have. If you didn't have G92 you most likely would have 2.59 or GM1.
Old 12-06-2001, 11:57 AM
dgoodhue
dgoodhue's Avatar
You have 2.73's. If you didn't have G92 option, you most likely would have had 2.59.
This case here is why you can't say that someone has 3.07 because the have G92, (Most of the time it is true but there are some exceptions)
Old 12-06-2001, 12:14 PM
Springer's LT4
Default Re: What is the gear ratio of the performance Axle in a 1994 Corvette? (dgoodhue)
So is it possible to have G44 (3.07) without the G92?
Old 12-13-2001, 11:57 AM
dgoodhue
dgoodhue's Avatar
Yes, but not likely on the later C4's. 84's came with G44 across the board, the G92 ratio was 3.31. The early C4's sometimes lumped G44 with the auto/Z51 package (85/86 I think) The 4+3 also came with G44.
Old 12-13-2001, 06:53 PM
GlockLT4
GlockLT4's Avatar
The hint is AUTOMATIC ... :rolleyes: :rolleyes: :rolleyes: :jester
A '94 with the "performance ratio axle" should be 3.07's. Oh, and all '94's with auto's had a Dana 36. Manuals had a Dana 44 with 3.45
[Modified by Glock'94, 6:29 PM 12/13/2001]
[Modified by Glock'94, 6:31 PM 12/13/2001]
To What is the gear ratio of the performance Axle in a 1994 Corvette?
Quick Reply: What is the gear ratio of the performance Axle in a 1994 Corvette?
