C4 head gasket needs to be replaced
I have a 1993 corvette 6 speed. my vette has 91,000 miles and I have been smeeling burning oil. So I took my vette to school ( im taking automotive classes at a college) and put it on a lift and saw oil around both my head gaskets. And it has been leaking onto my exhaust. So how hard is it to replace a head gasket on a LT1? I have all the tools and my instructor to help me. But how hard would this be?
I doubt your head gaskets are leaking. If it was leaking anything it would most likely be Anti-freeze, and your exhaust would be white smoke. You can do a compression test if you'd like, but you've probably just got leakey Valve Covers, or possibly Intake manifold. Clean everything up real good, run for a bit, and then see if you can determine the source.
Oil won't leak from a head gasket, only anti freeze. What is most likely happening is oil leaking from the intake above or a valve cover instead and working it's way downward. The oil then drips down and runs along the gap between the block and head gasket making it loook like it's coming from there. Check the front and back of the intake base for oil. They leak from there all the time.
Do a compression test or a leak down test if you really want to know about your head gasket.
I agree.. most likely not your head gasket but a leaking valve cover gasket or intake manifold (from the front of back of the manifold)..
Be thankful this is a much easier job than the head gaskets!!
Thanks for the replys, and I HOPE it is the intake or valve covers. But when I open the hood and look in the engine bay around the valve covers I can not see any oil leaking. But when I put it up on a lift and look up around the engine I see alot of oil everywhere but as far as I can tell, I could see oil running down the heads hitting my starter and exhaust. So If I am correct, there would be no oil coming from a head gasket, only coolant? and how hard it it to change a intake manifold gasket and valve cover gaskets?
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
We've changed intake gaskets on an LT1 (a 92 no less) in the parking lot of the Baymont hotel in Bowling Green during a corvette cruise in event with the most basic hand tools and a trip or two to the parts store......in under 3 hours.
I'd bet $$$$ that its you're intake gasket leaking. Do change the valve cover gaskets whilst in there though.
Use alot of brake cleaner to 'wash' everything down and remove the old oil thats everywhere.
RACE ON!!!
