need drive line specialist!!
It all started about a month ago...I installed new u-joints(driveshaft and half shafts), and after a while it was popping/squealing so i had a mechanic freind of mine look at it and i had apparently not gotten a collar tight on the right rear halfshaft where it attaches to the wheel. It had wobbled around in the coupling and wallered out the tab where its the u-joint is suppoed to seat in. A fellow forum member who lives close by(thanks blkzr1!!) happened to have a spare stubshaft?/mini yoke? whatever its called; He came over sunday and helped me remove the old one and install the one that he had as well as a new teflon washer behind it. We torqued everything back to specs and test drove it and it drove PERFECT!! over the next couple of days i have developed a horrible vibration in 1st and 2nd gear in lower rpms while under load, as well as when im turning and accelerating? What have i done? Any professional guidance would be greatly appreciated!!
-Chris
-Chris
I'd be looking at other points of the Drive line and suspension. this Vibration is only under a load, it has to be drive line related and/or suspension which includes wheel bearings.
