dual fuel pump pics or how to?
Old 01-30-2008, 01:52 PM
rtracy
rtracy's Avatar
Default dual fuel pump pics or how to?
I would like to make a dual intank set up. Would anyone have any pics of one or a how to? Thanks
Old 01-30-2008, 02:23 PM
mn_vette
mn_vette's Avatar
There are two popular ways of doing it.
1.) Run two pumps into two seperate lines and attach one to each fuel rail. Then use a single regulator and single return line. This requires putting a fitting in the sending unit to exit the second line from the tank.
2.) Run two pumps into a "Y" fitting and run a single supply line to the rails.
Either way you'll need to put a hole in the sending unit for the aditional electrical power for the second pump. JB weld works great for sealing those holes. You'll have to put a power relay in the power path and tie to to a key on power or perhaps a hobbs switch to turn on at a certain boost level.
I believe some Grand National places sell the "Y" fitting. Personally it was easier for me to run a second -6an line to the front of my car.
If you are worried about how to attach the pump, I just used two worm gear clamps and clamped the pumps together. Seems to be working great so far.
Old 01-30-2008, 04:22 PM
Bruce
Bruce's Avatar
The 2nd pump will need to angle a little because the factory sum tank will not clear it that was my experience. Here is some pics of my twin setup yrs ago. The pic shown I tied the 2 pumps together but I have to untie it because of the angle is needed to clear the sum tank
Do not run both pump full time because 2 (255lph) this suckers will emptied the your reserved gas rather quickly and will get you stranged on the road.
Old 01-31-2008, 03:07 PM
qwiketz
qwiketz's Avatar
Has anyone wired a second external activated by a hobbs switch? T rex pumps are a dime a dozen and I already have the heavy wiring to the external.
Also, blowerworks has a dual intank kit for like $129. I don't know any specifics but I did notice it this week when I was checking the fuel pump charts on their website.
Old 01-31-2008, 04:37 PM
rtracy
rtracy's Avatar
I don't think that includes 2 pumps.
Old 01-31-2008, 05:03 PM
qwiketz
qwiketz's Avatar
I don't think so either. I believe it's the add on pump and the mounting hardware (y block, ect).
Old 01-31-2008, 09:13 PM
djxib
djxib's Avatar
I'm going the inline pump route - I purchased the inline pump from Greg at Blowerworks, it mounts behind the number plate. I understand people have had good results with this set-up.
Old 02-14-2008, 11:11 AM
rtracy
rtracy's Avatar
What I want to do is run a walbro along with my stock pump but I would like to run it of the stock wireing at least the stock trigger wire.
I wounder if I can just splice into the stock trigger wire in front of the stock relay and use that to trigger both relays.
Old 02-14-2008, 07:09 PM
BAM92
BAM92's Avatar
I used this wireharness. http://www.racetronix.com/RX-C44-FPKG-2.html
To dual fuel pump pics or how to?
Quick Reply: dual fuel pump pics or how to?
