C4 conversion from auto to 6 speed manual
Hey, I am new here but I just finished the conversion of my 85 vette from an 700r4 auto to a 6 speed ZF transmission.
Wow, what a difference. I highly recommend.
Please note I had previously upgraded my rearend from the Dana 36 to a Dana 44. Failing to do this will just cause more headaches down the road.
It was fairly straight forward.
1. I purchased the complete swap from Fparts on ebay. Expensive but I got everything (they forgot to send the spacer for the clutch master, but they did send when I asked about it).
2. The clutch pedal install is actually pretty easy. I alloted an afternoon but I had it completed in an hour or so. (Be sure and get the correct pedal assy, I thing they changed in 88 or 89)
3. The starter interupt wiring from the automatic shifter connection needs to be extended to the switch on the clutch pedal assy- use your FSM, in the back there is wiring schematics.
4. Note that the pressure plates from 86 and up will not work on the 85 (two piece main seal crankshaft vs 1 piece crankshaft). I put a new GM short block that had the one piece so I had no issues.
5. Many people don't think you can surface the 89 and up flywheels but I had the local machine shop do mine with no issues.
6. ZF transmissions must use GM or BMW special fluid (basically motor oil). The local BMW dealer want $18 per quart. I order from Bavarian motorsports for $9.
7. The ZF tranny weighs about 150lbs. Takes two people (Although I did mine solo).
8. The transmission reverse light connector can be a pain to find. The local parts store had the correct connector. I then extende the reverse wiring from the auto gear selector connector to the 6 speed connector on the transmission. (refer to the FSM wiring schematics)
9. You will need to order a new shifter trim plate for the center console.
Anyway, I know one or two others have done this, so I thought I would post this.
Very cool.
I'm planning on doing this or swapping in a Richmond 6-speed in the future.
Feel free to share any more info if you have it, and keep the pics coming if you got them.
http://members.cisdi.com/~anesthes/zf6/
-- Joe
Correct, that was typo. I meant flywheel.
Re spacer- There is a 1" spacer on the engine side of the clutch master cylinder.
The BMW oil was per ZFDOC.com. I found the site very informative and they know their stuff. At worst I over spent for the synthetic oil.
Chris
1" spacer on the engine side of the clutch maser cyl.. Hrmmm.. I don't have one. Got a picture?
--Joe
I'm not too experienced with the DM flywheel specific to the ZF tranny, but I'm plenty experienced with the DM flywheel that Ford used on their diesels and it's a similar design. I've seen several break a spring resulting in a SEVERELY imbalanced engine and a tow home. If I had a ZF tranny I'd switch to a single mass and just bear the new rattles for the peace of mind that my flywheel doesn't have any moving parts and springs. Has anyone had a vette DM flywheel break a spring?
It's the same as a horn connector on early/mid 90s GM cars, as well as the ABS connector on these same cars. Go to the junkyard, look for like a '92 lumina for example.
Theres about 5 million of them in the junk yards. Thats where I got mine.
-- Joe
-- Joe
