engine rebuild question please
Old 01-24-2008, 03:30 AM
emo-vet
emo-vet's Avatar
Default engine rebuild question please
hi guys,
im getting back my freshly machined block early next week that has been acid bathed,bore and honed and decked ready to fit new engine parts.
i have ordered a engine cover bag for the block,but cause i wont be installing crank,pistons,rods for a while i wanted to ask you what can i spread/rub on block on decks and cylinder bores so they dont rust up ??
can i use grease or vasoline may be??
or engine oil or installtion lube may be??
is there a specilised product for this job ??
i guess it would be good if this product doesnt run of the metal easy and is easy enough to clean when time comes to install parts
any ideas please guys??
thanks
shae
Old 01-24-2008, 06:54 AM
Happydad
Happydad's Avatar
Ive used LPS heavy duty Rust Inhibitor. ..I've got a block in my shed for about a year and it still looks good..It's kinda waxy when it dries but comes right off with that orange degreaser stuff(any brand)...You can get it at Napa I think...
Old 01-24-2008, 01:53 PM
emo-vet
emo-vet's Avatar
hi happydad,
thanks for the reply mate!
cheers
shae
Old 01-24-2008, 02:02 PM
black_771
black_771's Avatar
WD-40 has worked for me on a block that is over 3 years old. No rust at all.
Cheap solution that works just as well in my trials.
Old 01-24-2008, 06:07 PM
Bad Karma
Bad Karma's Avatar
Same I've used, and we have had blocks sit for well over a year this way with no signs of rust.
Old 01-24-2008, 07:05 PM
Happydad
Happydad's Avatar
Originally Posted by emo-vet
hi happydad,
cheers
shae
Waz-Up Shae...Havent you got that thing built yet What are ya waitin for ..
Old 01-24-2008, 07:08 PM
93-383's Avatar
Spraying light oil on it should be fine. However if its stored near the ocean (sea air) I would apply something a little heavier like cosmoline
Old 01-24-2008, 07:42 PM
jsup
jsup's Avatar
Location: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Go to the local marine store and ask for the storage oil.
This stuff is made for the outside of blocks and burns off when the motor is run. It's very sticky.
Old 01-24-2008, 08:30 PM
comp
comp's Avatar
have brushed on STP
Old 01-24-2008, 08:51 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
I just use regular old oil and bag it up good.
Old 01-24-2008, 09:05 PM
jsup
jsup's Avatar
Forgot to mention it comes in a aerosol.
Old 01-24-2008, 11:32 PM
emo-vet
emo-vet's Avatar
hi there all fellas,
cool,thanks all for your replies guys.
much appreciated !!
i never thought about using wd-40,good idea.
i guess i will try that one first,then others later if needed.
r.e what happydad mentioned,yeah im doing bit by bit as im on a budget.
but just about have all the parts and hp parts now to build the beast!
i gotta tell ya though,i cant wait
cheers guys
shae
Old 01-25-2008, 01:30 AM
rodj
rodj's Avatar
"i wont be installing crank,pistons,rods for a while "
You going to put it together yourself?
Old 01-25-2008, 02:35 AM
emo-vet
emo-vet's Avatar
hi rod,
how are ya.
no mate, i wont be puting it togeather myself.
i mean to say the engine builder.
btw mate, i brought some quality castrol 15w40 diesel oil like you mentioned for the run in procedure.
thanks
shae
Old 01-25-2008, 07:38 AM
JLeatherman
JLeatherman's Avatar
I use WD-40 on my blocks. In fact, that's exactly what it was designed for. "Water Displacement" formula 40 was designed specifically to keep moisture off of metal. Always worked well for me, cleans off easily with alcohol for painting later, and I kinda like the smell .
Old 01-25-2008, 02:09 PM
jhammons01
jhammons01's Avatar
Well WD-40 is a solvent so it would not be my first choice.
Not to mention WD-40 attracts dust and then falls off.
An Engine builder from VW in Wolfsberg years ago showed me what He called "assembly lube" I saw it again from a completely different source when I was tinkering with RX-7s.
Assembly Lube is a 50/50 mixture of Marvels Mystery Oil and STP oil treatment. You get an old style oil can....the one that has a spout and thumb trigger.......and you mix them in there and squirt a healthy amount on surfaces that may rust and especially surfaces that have parts that contact each other.
My .02 for what it is worth
Old 01-25-2008, 02:37 PM
94z07fx3
94z07fx3's Avatar
In addition to your oil...
Toss in several of these guys...
wrap it up with this...
And you'll be using the same solution that GM uses when they make and ship engines.
To engine rebuild question please
Old 01-25-2008, 02:48 PM
JLeatherman
50/50 mix of Valvoline 10w-30 and STP is what I use for assembly lube. I coat the bearing surfaces, pistons, cam, etc during assembly. For the outside of the block, however, I think it would be pretty difficult to clean off for paint. STP is some pretty sticky stuff...
Old 01-25-2008, 03:01 PM
jhammons01
jhammons01's Avatar
and further thinking, wouldn't now be the time one would/should be applying engine paint to the external areas of the Block?
Masking any mating surfaces as well as any holes.....then blasting it with a high temp engine paint would be my first choice for preserving the outside areas of the block.
Old 01-25-2008, 05:56 PM
emo-vet
emo-vet's Avatar
hi there all guys,
ok thanks for your further help and advice.
much appreciated !!
cheers
shae
Quick Reply: engine rebuild question please
