Drag Radials or Slicks
Old 11-30-2001, 02:55 AM
black_89_vette
black_89_vette's Avatar
Default Drag Radials or Slicks
At what point do you transfer from the drag radials at the track and start using slicks. I have seen some people's posts with drag radials getting low 12's, maybe even lower. Obviously slicks would work better, but what are the lowest times seen with people running the drag radials? This will be a much cheaper option for me than buying slicks and rims to fit them.
Old 11-30-2001, 08:07 AM
importeater
importeater's Avatar
Default Re: Drag Radials or Slicks (black_89_vette)
i've seen more people swear by the nitto 555R as being a far better tire than the BFG for a drag radial. a good friend of mine made a pass at 11.4@126mph on a 315 35 17 nitto 555R drag radial. this was a bolt on modified C5 with a fairly good wet shot of NOS. traction was absolutly NO problem for him. the other thing you should keep in mind with a full on slick, espessialy a wide sticky one is...what gives when you drop the clutch at 3000rpm? if the tires don't, all the strain is on the drivetrain. some tire slip taking off is a good thing in my oppinion.
Old 11-30-2001, 09:12 AM
Beach Bum
Beach Bum's Avatar
Default Re: Drag Radials or Slicks (importeater)
11.4 @ 126..... sounds like he had serious traction problems.... 126 mph traps are good for mid 10's if you can run a good 60 ft. As a note, I think any tire spin whatsoever is a very bad thing.
From what I've noticed, based upon a fairly stock suspensioned vette.... 26" drag radials are good to 1.75 60 fts consistently. You can run them into the mid to high 1.6's, but your consistency is going to suffer when you're that quick, unless you're lucky enough to run on a perfect track all the time. It looks like with the 28" drag radials you can run another 1 tenth quicker before running into the same consistency problems. With your 383 SR motor, you're going to want to at least run the 28" drag radial or ET Street to have any type of consistency.... the traditional 26" bfg drag radial or Nitto drag radial are not going to deliver you consistent 60 foots...
good luck
Beach
Old 11-30-2001, 10:19 AM
Vic'89
Vic'89's Avatar
Default Re: Drag Radials or Slicks (Beach Bum)
Beach
I have to confirm Beach Bum's post. I have run the BFG DR's this entire year and can get 1.79 - 1.80 60' consistantly on a decent track. I have a bone stock suspension.
Vic
Old 11-30-2001, 06:20 PM
Red Rocket
Red Rocket's Avatar
Default Re: Drag Radials or Slicks (Vic'89)
Beach is right. If you are driving to the track and just having fun go with the Nitto's or BFG's. If you want consistency and the best 60' in serious racing conditions, put on the ET Streets. Six speeds are more inconsistent with the DR's. A 1.7 60' with a six speed is not easy on DR's. Driving the 396 and 4.09 gears with the Nitto DR's is making a 1.7 even more of a dream.
[Modified by Red Rocket, 4:28 PM 11/30/2001]
Old 11-30-2001, 09:38 PM
importeater
Default Re: Drag Radials or Slicks (Red Rocket)
totally agree with you guys on most of this. the C5 i was talking about still has the stock clutch in it & is slipping a tad on take off, i'd really hate to see this thing go on drag slicks. however the point is made the clutch is the problem & not the tires. if i remember right his 60ft time was in the 1.8-1.9 range most the season. nittos seriously are a track favorite around here but if your doing times like that on the BFG i might pick up a set as i have wholesale with tire rack. good to know :cheers:
Old 11-30-2001, 11:34 PM
11sec84
11sec84's Avatar
I agree with Beach as well. I was using BFG Drag radials and had to baby the thing before I could hammer it. I tried a friends Nittos and they would go up in smoke as SOON as I hammered it. I like the BFG way better. I now have ET streets and they hook with out even so much as a chirp. No tire spin leads to lower ETs. If you need tire spin to save the clutch, buy a better clutch.
Old 11-30-2001, 11:52 PM
meach13
meach13's Avatar
Default Re: Drag Radials or Slicks (11sec84)
nitto drag people here
turbovette has run the best of
1. 60ft 1.54 *ouch ouch
1/8 7.03 @ 98
1/4 11.01 @ 125 "New
this is with stock suspension
we run anywhere from 1.60-1.64 every pass unless the track is really slick http://www.meacham.pointclark.net
[Modified by meach13, 9:53 PM 11/30/2001]
Old 12-01-2001, 01:33 AM
neat
neat's Avatar
Default Re: Drag Radials or Slicks (meach13)
I don't have any tire expirence on a vette, but with my T/A...
Nitto's suck unless you heat the shi+ outta them. Cold, they are worse than a regular street tire. They last longer than a BFG's, unless you go to the track alot. Then the HUGE burnout that is necessay to heat them up begins to take it's toll. BFG drag radials hook just as well (IMO) with a smaller burnout.
Unfortunately, ET streets are where its at. This is by far the best track option. Unfortunately if you like to street race, there are obvious drawbacks to taking out the ET streets and bolting them on infront of potential competitors. If you run them all the time, they will die REALLY fast.
Just my .02
Old 12-08-2001, 02:00 AM
corvette7591
corvette7591's Avatar
I have seen mustangs in the 10's on BFG, at darlington dragway.
Old 12-08-2001, 08:55 PM
fioremike
fioremike's Avatar
hi i have a very similar set up to you on a 91 with a good burn out i was able to do a1.57 60 and plenty of 160 60"s on bfg drag radials best run 11.880 with a trap speed of 113.62 one other thing my car is a automatic
[Modified by fioremike, 6:58 PM 12/8/2001]
[Modified by fioremike, 7:00 PM 12/8/2001]
To Drag Radials or Slicks
Quick Reply: Drag Radials or Slicks
