Singlemass ZF6, ZR1 pivot stud, snakeoil?
OK..
Someone.. Had done a swap to a ZF6, and used a 4+3 singlemass flywheel. Someone also has stated that the "longer ZR1 stud is needed because the singlemass flywheel is thinner than the dual mass".
I spoke to CentralCoaster. He doesn't know. He said he hasn't tried the ZR1 stud.
So before I go and BUY A STUD, since I need one anyway mine is stripped.
WHO has done this swap, and what stud did you use, or specifically, has anyone had success with the ZR1 stud or did it make the slave cylinder travel too far?
I want to hear from a guy (or girl) who has DONE it. Because I found 50 billion threads with "you need to" but they were all written by guys who hasn't "Done it" so I can't decipher the myths from the facts.
-- Joe
-- Joe
Give Bill at www.zfdoc.com a call, he's done a couple of those swaps recently and should be able to give you the info you need. Also, he's probably still up and working right now!
Most use the Camaro flywheel. It needs to be machined .090".
I've never used the ZR1 Stud/4+3 FW combo.
FWIW, the ZF geometry and dimensional stack ups are so sensitive, that I gave up on the ZF stuff parts. Plus you a re limited to certain expensive clutch components.
I know how to make it work as well or better without the ZF parts so I don't use them
Essentially, I use a 4+3 FW , PP and Disc, .100" spacer between the BH and Block, and a Hydraulic Howe Push Type slip on TOB, a Wilwood 3/4" bore Master Cylinder, and a Clutch Pedal travel stop.
Believe it or not, the BMW's use a Pedal Stop as well.
-- Joe
Joe,
Here is what I did. This doesn't answer your question on the 4+3FW/Push type clutch, but gives you an example of what can work.
When I swapped to the ZF 6 speed in my 85 4+3 I used a Fidanza aluminum flywheel that was specifically made for the older 2 piece rear main seal blocks and the stock ZF clutch set up (non ZR1).
With this flywheel I used the stock pull type ZF clutch, shorter L98/LT1/LT4 pivot stud, later LT1/LT4 magnesium bell housing, and later LT1/LT4 clutch master cylinder and slave cylinder. It is also possible to use the earlier L98/LT1 aluminum bell housing, it depends on what you want to use and what starter you want to use (the earlier bell housing uses the large nose starter and the later magnesium bell housing uses the small nose starter).
Just remember the clutch (it’s really just the throwout bearing) has to match the year of your transmission, early black tag or later blue tag because the throwout bearings have a different ID size.
If your 87 has the one piece rear main seal then you can use the stock ZF dual mass flywheel or an after market single mass steel or aluminum flywheel for the ZF 6 speed Corvette, more choices.
I do not have experience with the push type clutch conversion for the ZF but others have shared about doing this. I have 572 HP at the crank and use my car for track days and the set up I described above has been working just fine for my set up and car use.
Brian
Brian
Joe,
Brian
Brian
I appreciate the response. I've compiled kinda a 'faq' on the ZF6 based on my measuring, and interviewing/talking with folks like yourself who have 'done it'.
http://members.cisdi.com/~anesthes/zf6/
Your aluminum flywheel which is a direct replacement for the dual mass is probably the same thickness as the dual mass it replaced. So it makes sense that you were able to use the stock pivot stud.
Central Coaster also used the stock pivot stud, and hes using a stock 4+3 flywheel thats even been shaved.
So the question is, has anyone actually used the ZR1 pivot stud or is it a myth? If you search, I see lots of advice to use one. But have yet to actually talk to a guy who did.
Thanks!
-- Joe
Yeah that seems pretty common. Pretty much direct from the FAQ. I'd have imaged more people though who have swapped from a 4+3 would have re-used the single mass flywheel. So far myself and Centralcoastar are the only ones I know of. So where does this ZR1 stud thing come from?
-- Joe
http://forums.corvetteforum.com/show...inglemass+stud
One guy says use it, then says don't use it. The idea seems to be floating around..
-- Joe
St. Jude Donor '10-'11-'12-'13
http://forums.corvetteforum.com/show...ight=zr-1+stud
-- Joe
-- Joe
In the early stages of my swap, I was going to use my 4+3 flywheel and a longer pivot ball stud, as recommended by TPIS (I have a write up from them that I'll try to post later). Because the 4+3 flywheel will not work with a sprung clutch disc (and I wanted to go with a sprung disc), I went with an OEM dimension aluminum flywheel and back to the short pivot ball stud, so I can not fully verify whether or not the longer stud is actually needed for the 4+3 flywheel. You mentioned CC uses the shorter stud and a 4+3 flywheel, so it obviously can work that way, but I don't know what length bell housing he is using or if he is using a spacer between the engine block and bell housing. Little things like that DEFINITELY make a huge difference when tolerances are already so tight.
This weekend, I'll compare depth measurements of my original 4+3 flywheel with the OEM dimension aluminum flywheel and post results. I'll also compare the long pivot stud with the shorter stud as I have them, too .
I think that guy you are referring to is me. I don't believe I contradicted myself in either thread. In each case I pointed out that a short pivot ball stud needs to be used with an OEM dimension flywheel. The longer pivot ball stud is recommended for use with the thinner 4+3 flywheel, but as LD85 pointed out, the geometry and dimensional stack ups are VERY sensitive.
Someone had told me there is another depth bell housing, a more shallow one which is supposedly 5.850" or something like that (for a ZR1 perhap?). So Say we have this shallow bell housing that's already nearly 1/4" closer to the flywheel, I can't see how a ZR1 pivot stud would help there. And since we know that central coaster is using a 4+3 flywheel (which was even resurfaced) with the 6 1/8" bell housing, and a normal length stud than we know that combination works. So I guess i'm even more stumped now as to why this ZR1 pivot stud is recommended.
-- Joe
I swapped my 86' over a couple of years ago, it's not that bad. I used the lightened steel flywheel from GM that is for the 4+3 corvette, a camaro disc (Zoom Purple), ZF pressure plate and throw out bearing (Valeo) The longer stud, ZF master and slave cylinder, and line was used also. I didn't change the clutch pedal but I changed the bushing in it. It was well worth it. With the 4+3, sometimes I had OD, sometimes I didn't. Also installed the B&M Ripper (firm shifts).
Good luck, Joe
Good luck, Joe
Good luck, Joe
Good luck, Joe
Now I'm confused again!
-- Joe
worked fine but i overtightened the original bolts of the clutch:o :o
so i had to take it out again and now im driving with the original flywheel with a centerforce DF clutch & plate works fine to
but with the fidanza i really felt the revving difference
i also tried the 4+3 flywheel with a kevlar plate [with springs from TPIS] and original clutch
but had to take it out because i had unbalance beyond the 4500 rpm
greetzz jeff.
If I remember correctly, The ZF disc hits the pp bolts of the 4+3 flywheel, so the camaro disc is used. That advise and the longer stud came from McClod. I used their disc first (didn't last long).
Joe
Joe
