LS2 into C4
LS2 into C4
I read the LS1 transplant FAQ, which was very helpful. What I'm wondering is if anyone has ever done an LS2 into a C4? How much different would it be than the ls1. I'm thinkin LS2 with TH400 and gear vendors overdrive unit. Any problems one would think I would run into?
There have been a few on this forum that have done an LSx swap. Hopefully, they will chime in and help you out. It looks like alot of headaches to me.
-Mike
-Mike
I would use a 4L60E, since you can swap the 700R4 tail shaft housing onto the trans and have a bolt-in solution. Externally, an LS2 is the same as an LS1, so it will bolt it no problem with the SpeedHound motor plates, and you can run Melrose swap headers. After swapping the tailshaft, you just need to drill some holes in the c-beam.
The fun part will be the wiring.
engine: $2000
trans: $2000? Not sure what a built trans costs
motor plates: $100
headers: $700
wiring harness: $700
Computer: $200
c-beam mods: $100 ??
It all adds up really quick, especially if you want to build the engine or trans. Not saying you shouldn't do it, but, rather, it won't be that cheap.
Former Vendor
It's only bad when you start out using expensive motors. I would go from the stand point of how much power do you want to make, how much money do you want to spend, and are there any other goals you'd like to obtain. For instance, you can build a 6.0 truck motor to 450 rwhp for less than any LS2 will cost you. It will not save you much weight though if that's a goal. The tighter the budget, the more compromises you must make. I'd give up weight to make more power when we are talking a lot more power or heck even just to get the project done and down the road. You've got it easy starting with an early C4. The ZF guys hate this swap because they can't use their transmissions at all. You could if you wanted to use your 700R4 or you could easily swap to a 4L60E. The 4L60E can easily handle an LS2. Once you build the LS2 you'll need to also build the 4L60E. That's normal though. I would not go with a TH400 and an GV OD unit. Too much weight and too many issues making it work with the Cbeam. What Mojave said about swapping tail shafts and drilling holes is correct when using my plates. It really is that easy to get the engine/trans into the car. The headers are readily available. The wiring is extensive but not hard. I'm still working in an AC solution but do not have one right now. DeWitts makes a radiator/fan combination that will cool the engine. The stocker may work fine as well. I'd rather upgrade though. Random Tech will be making their dual exhaust system fit up to the headers. So potentially you could build the exhaust system in your garage without going to a shop. Or you can take it to a shop and have it custom done.
Don't give up on this unless your plan was to just throw money at the car to make it happen. It's labor intensive so it will cost a lot if that's your approach. If you take your time and spend wisely, you'll be able to get very far for not a lot of money.
Feel free to ask any questions you may have. This next issue of Corvette Fever I think will have some more info on C4orce. Specifically engine information.
Trey
Trey
You can build a 4L60E to take a good amount of abuse. I can't imagine doing an LS2 swap and using a 3 speed trans.
I looked into this for my car, and I figure at least $6K to get it done.
engine: $2000
motor plates: $100
headers: $700
Computer: $200
engine: $2000
motor plates: $100
headers: $700
Computer: $200
I'm not doing the build because its cheap I'm doing the build because its what I want. If I was going to do it cheap I would try and mod with the L98 that I already have and try and be happy with 300hp haha. I figured quite a bit higher than your figures too.
Trey
Trey
If you're worried about the harness and tuning you can now convert an LSx to carb. You'd still have to build your timing #'s as the ignition would be controlled by a GMPP available controller.
Thats the beauty of the Gear vendors unit. It splits each gear making it a six speed. Just a three speed wouldn't make sence. This car is going to be a dd. I want good mileage and still be able to go out and slap the gears on the weekend.
Why would you spend all that time and money to swap to an LS2 and NOT use the fuel injection? The FI setups on LSx motors are very, very powerful and flexible. You can tune it to run with all but the most extreme engines. If you want a carb'ed motor, why not just keep an SBC and avoid a lot of wasted time/money?
