Hood Latch Bolt assembly part number?
St. Jude Donor '03 & '05
UPDATE! Parts not really available, but fixed. Hood Latch Bolt assembly part number?
My 93's hood keep popping up on the passenger side. I have adjusted everything in the assembly and latch section per FSM. I even put a cable in there and adjusted it all the way out, to make it tight, and I use the cable to pull the latch.
If anyone has ever dealt with this assembly and know the part numbers/pricing etc, I would appreciate the help.
Well as I was driving down the highway and hit a few bumps I noticed the right side, which I have been having problems with, bounces up and down when I hit bumps. But it is adjusted so I cant move it down at all or pull up when I actually use my body weight to push the hood down.
So, could it be as simple as the springs are bad. I do open and shut this hood allot!
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Below in PDF format are the pertinent pages from the C4 Parts microfiche, if that's any help to you:
I couldnt find parts to replace my hood pins etc as they are discontinued. So, A felllow forum member Jared, hooked me up with his OLD ones
Well you can see his OLD ones were in tip top shape compared to mine.
I will reuse my spring as it is the fat one. But look at the pin and you can see how mine was chewed up and not grabbing the latch. I hope this fixes it from popping up.
