84 vet coolant fan prolems
jus got it other day winter here so nawt drivin it but (like some one else id read) was messin with the rear speakers n ign. on radio on n car went dead charged bat. n all seemed fine tell turnt key on the coolant fan ran right off check coolent sensor n still ran ony way besides key off is to pull the relay put in new relay n same thing probed n messed round n were just test the relay plug wid a test light n green n black were ground cause would lite blue n red then tested again n the red would lite nawt the blue (hoped yea somthun unstuck) no luck no the fan wont run at all turnt air on no fan let heat ta 235 no fan kin you dudes help a fool out thanks pappy
ok found the blown fuse now i r back ta square 1 (yea i r lookin fer a book)but az said jus got it so now i r at fan runs soon as hit key unless unplg relay n new realy is same way n have had bad relays fum box so nutha commin in morning any idears fellow rednecks
there is a fan switch in your pass side head try changing this to see if that works. before you do that take a look at the wiring that goes to the fan mayby someone re routed the wires so that it is on at all times.
RACE ON!!!
Took me a while but I think he said his fan comes on as soon as he turns the key on, unless he unplugs the fan relay all together.
That it does the same even with a new relay. And that he has had new relays prove defective out of the box.
Sounds like the fan switch on the passenger cylinder head is bad like Scooter said, or the wire from it is grounded/shorted out. Basically, unplug the fan switch, and see if the fan stops running. If it doesn't, the wire from it, to the relay, is shorted to ground. The switch is mounted between number 6 and 8 spark plugs.
And speaking of sense. I'm not faulting the interpretation, but if you are right, 86PACER, his actions make no more sense than his writing. If he knows "...that he has had new relays prove defective out of the box.", then he knows a good from a bad relay. If so, I have to wonder why, "it does the same even with a new relay", he changed the relay in the first place???
Based on your best guess, I'd have to say scooter18155 and Jamey are on the right track.
RACE ON!!!
1st scooter yeup ive checked it fan still runs evin wid sensor unplugged
2nd thank u pacer fer interpitting thats wud i said ive built a few ol harleys n have kept many a runnin n thats where the junque relays have came ta play
3rd kin i say i asked fer help nawt a angalashia language course i know i type like a foo i r a foo hey have wid it but do preciate the help also
ae fer the good bad relay know the dif.. hey they werk er they dont as ya said cfi i rekon the udda two have ta be right gotsta be a ground offin that sensor cause ony way ta stop fan is turn key off er unplug the relay ony had car couple daze n dint do that befoe so hafta trace that wire underneath n see ifn melted somewhere any udda idears be preciated thanks fellow rednecks pappy the illiterated derilected freebird woot woot hey wait tell iask bout the brake booster er the wiper washer pump God knows i hope that be bout it but betta fug up er fix up wud im after thanks again peoples
well pappy sounds like you got to trace some wires to see if you can find your problem. it sounds as if thats your problem. like cfi said a fsm will do you wonders. and the coments about your typing isnt meant in a bad way its just that the better we can understand you the better we can help you. as far as im getting you determined (1)the relay isnt your problem and (2) the switch in the head isnt causing your fan to come on you also need to verrify that someone hasnt hot wired your fan to stay on at all times. look at the wires going directly to the fan and follow them to see if they go to the correct places or if someone spliced them somewheres they shouldnt be. some backyard mechanics might wire a fan this way to help keep engine temps down. also check the wires jamey mentioned it is possable those wires went bad as well.
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
wo i wuz sayn ur sensez ot to get da *** out coz wout allzat inna way u cant get
no traccton wif yo ride n we all need if wez gonna get sum puzza tonieete woo woo bro!
fan was fine befoe...so nawt wired direct... unpluggin relay n turnin off key is ony way ta stop fan... unpluggin rightbank sensor n fan stays on...it should stop ifn sensor bad right??? n the sensor in the aircomp.will stop fan when unplug also.... so since two of 3 will shut it off....could it be the rightbank sensor??? i were told they shut off when unplug ifn bad ...n it doesnt so figure good... i afta chase a wire i rekon...thanks rednecks the pappster ..nee any help wid ol shovelheads maybe i kin return the favor
When a battery is disconnected then reconnected, the air conditioner turns itself on. When the air conditioner is on, the fan runs continuously. Turn the a/c off and I'll bet the fan turns off.
ok ...wud bout this...the air is off... did try it utha day n comp.dint turn on... anyways ifn i unplgu the comp.pressure switch (in comp still) it shuts off the fan... so its the comp switch thats grounded... hatsa be..right???? so kin low freon cause this??? n idjuts test could be ta unplug the comp.switch ...n run car tell hits 220-230 n fan should come on then correct???? yea baby am i onta somthun here ..er jus jerkin my own chain heyhuh!
Now learn to write in coherent sentences...In ENGLISH!
RACE ON!!!
geeze cfi!!! fer a cat dat wrote a book ....ya should take yer own advice n quit givun me cheeyut... thanks fellas i test it n let ya know...so now how do i fix people??? now thats palin angalshia ain it cfi?
RACE ON!!!
