Did Rome have to use the Exotic Muscle narrowing kit?
You will have to ask ROME.
The narrowing kit is the same one GM designed and used in there Big Doggie 454 1990?Corvette when they put ZR1 wheels on and needed the wheels to come in. They were able to get them in 13mm's so they didnt stick out as much.
Bluewasp, your car is the reason I'm wanting these wheels.
Are yours 18" and are those 335s on the rear? If so, did you have to do anything to get them to fit?
Yes 335x18 tires. I had to cut the rear quarter panels to get them to fit. This offset puts the rear tire under the GS flare. About an inch further out then Rome's setup.
No, i had to cut fiberglass right behind the quarter flare, the rear quarter panel itself. No cutting required if the car is at stock height. Didn't bother me because the flares are screwed into the panel so if I or someone wanted to remove the flares they would have to fix those holes. Whats one more cut in the glass...
