Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-29-2007, 12:16 PM   #1
lumij3
CF Senior Member
lumij3's Avatar
Default LT1 Heads on L98
Is there any advantage in changing the L98 heads for LT1 heads. If so, what's the advantage and can I do it easily?
LJ
lumij3 is offline   Reply With Quote
Old 11-29-2007, 12:48 PM   #2
ToniH
CF Senior Member
ToniH's Avatar
No and no.
__________________
'70 LS5 Coupe *** '91 L98 Coupe
My Vettes
ToniH is offline   Reply With Quote
Old 11-29-2007, 12:49 PM   #3
vader86
CF Senior Member
vader86's Avatar
Nope. next idea.
vader86 is offline   Reply With Quote
Old 11-29-2007, 01:08 PM   #4
lumij3
CF Senior Member
lumij3's Avatar
thanks. What would be a nice set of heads and cam for a l98 with ported runners and plenum, 52mm tb, street runner ship, open air filter, corsa exhaust sys.? I used to owned a 2001 cobra it made 350 hp, and I would like to get the same rush when driving my vett.
lj
Old 11-29-2007, 01:49 PM   #5
ToniH
CF Senior Member
ToniH's Avatar
AFR Eliminators 180cc are nice heads for your application.
You might need to do a bit more on the intake parts to get the 350hp feeling you seek. I mean there is lots of nice cams but the intake might be restricting you. At least port the heck out of the base plate if you are not interested in upgrading the TPI. When your intake is sorted you can choose the cam. Crane, LPE and even GM have many good options.
PS. what year is your car? You might need to get a engine specific chip made to get everything out of it and to make sure it works ok.
PS2. also rear end mods and a good torque converter will help and might even be cheaper than the engine mods.
Old 11-29-2007, 01:54 PM   #6
redrose
CF Senior Member
Quote:
lj
'stangs are oem trans/rear axle geared for 1/4 mile, vettes are oem geared for insane top end/ cafe fuel consumption...you choose.
lt1 heads have been installed on the sbc1 block, not really worth the gymnastics...the lt1 intake modded to fit sbc1 (L98) heads/block rocks.
redrose is offline   Reply With Quote
Old 11-29-2007, 01:57 PM   #7
vader86
CF Senior Member
vader86's Avatar
Your stock heads, ported.
LPE 211 or TPiS ZZ-9 camshaft.
Then a custom chip, toss the streetrunner junk.
Old 11-29-2007, 02:26 PM   #8
lumij3
CF Senior Member
lumij3's Avatar
It is a 1988 conv. By rear end mod do you mean Dana 36 with 3.73 ring and pinion? Also when talking about a good torque converter what would be your sugestion? Thanks again
lj
Old 11-29-2007, 02:27 PM   #9
lumij3
CF Senior Member
lumij3's Avatar
Yes, stock heads ported to the max without siamesing.
Old 11-29-2007, 02:29 PM   #10
lumij3
CF Senior Member
lumij3's Avatar
better or equal to Accel Super Ram?
Old 11-29-2007, 02:35 PM   #11
lumij3
CF Senior Member
lumij3's Avatar
Add to this equation headers, Do they make any difference when trying to gain torque and hp.?
LJ
Old 11-29-2007, 02:47 PM   #12
ToniH
CF Senior Member
ToniH's Avatar
- 3.73 too high for L98 and automatic transmission. 3.07 better.
- for modified L98: 2600-2800 stall tc. Search for tc threads by PeteK
- LT1 intake vs. SuperRAM - which is better? not comparable at same rpm, do a search, >24000 threads about them.
- headers: yes very good for L98. Search for hookers, stainlessworks.
Old 11-29-2007, 03:01 PM   #13
vader86
CF Senior Member
vader86's Avatar
An 88 with this setup would need 2200-2400 rpm TC, if driven alot....if a drag only car go a couple hundred rpm higher.
3.73 wayyyy too low a ratio for this setup. Needs 3.07, nothing lower.
Headers=always.
Once you start talking about changing to LT1/MR or SR, then everything has to be reconsidered from scratch. If you want to optimize it for right now, then do what we've suggested. More is on my website, click my name.
Old 11-29-2007, 03:17 PM   #14
ToniH
CF Senior Member
ToniH's Avatar
too high / too low - well we mean the same anyway
Old 11-29-2007, 04:15 PM   #15
lumij3
CF Senior Member
lumij3's Avatar
Thank you for your help.
LJ
Old 11-29-2007, 04:17 PM   #16
lumij3
CF Senior Member
lumij3's Avatar
Headers=always.
LJ
Old 11-29-2007, 10:47 PM   #17
Orr89rocz
CF Senior Member
LT1 heads have more material on them and can be ported to near 290cfm. L98 heads seem to cap off at 250-260 from what i've seen.
BUT then again for the amount of work you will do to the LT1 heads to get them to work, then portwork involved, if you cant do any of that yourself, you can get AFR eliminators for 1450 and flow 280ish cfm out the box so it will make power.
but they are generally overkill if your not looking for big power and big cams. BUT even with smaller cams its good to have more head flow than anything. As long as your intake can flow the cfm needed for your hp goals
Orr89rocz is offline   Reply With Quote
Old 11-30-2007, 03:09 PM   #18
lumij3
CF Senior Member
lumij3's Avatar
As I am trying to calculate how much is all this going to cost I am coming to nearly 6K and that is doing all the work myself. The q? is: Is this worth it in a '88 corvette or should I try to sell it plus the 6 grand that I would use to try to make decent torque and hp and buy another year like in the '90s that comes with at least 300hp? Did I buy the wrong year?
LJ
Old 11-30-2007, 03:32 PM   #19
redrose
CF Senior Member
LJ
nope...you have one of the best.
trash the tPi and put just an lt1 intake on and you have 300 hp, other mods when you need more.
Old 11-30-2007, 06:43 PM   #20
Corvette Kid
Large Upstanding Member
St. Jude Donor '04-'05-'06-'07
Support Corvetteforum!
Corvette Kid's Avatar
Headers=always.
If you get your HP peak up to near 6K or so, you'll want to consider more converter, even for a street car. I use a 3000 stall Vigilante on the street and while they're admittedly pricey, it drives like a stocker in normal driving. Plus, it saves about 17 lbs. of rotating weight over a stock sized converter. That's a big plus in power, the speed at which the engine wraps up and in overall efficiency.
Corvette Kid is offline   Reply With Quote
Reload this Page LT1 Heads on L98
Tags
300, 350, accel, block, conversion, corvette, engine, head, heads, hp, intake, l98, lt1, mods, superram
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
