canton road race oil pan fit with headers?
will the hooker super comp headers fit with the canton road race part#15-240t oil pan in a 91? is anyone here running one of these pans with headers .Im thinking they might hit the side kick outs of the pan . I hope it wont because i would like to get one .thanks in advance
makn u shiver,
Here are a couple of pictures from the underside of my car, 1985, with TPIS headers and a Conton road race pan. I have no clearance issues. Not hooker header but maybe this helps.
Brian
Brian
thank you very much this is a huge help.It looks like there is alot of clearance between the pan and headers,now i can order one .thanks again
Don't know about Hookers but my Hedmans fit fine with the Canton pan. I would say that if the Hookers resemble VanSpeed's then you should be fine.
Large Impressive Member
Location: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I've got plenty of clearance with that pan and my Stainless Works headers too. I think we've covered about everything except the Hookers now! You should have no problems. There's so little room for variance in that area, that all C4 headers are going to be very close in the distance between the collectors.
Thats great now i know i will have no issues with the headers.Maybe i should post a wtb ad in the parts section .It seems like a lot of you guys run those pans there has got to be one floating around .
