Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ Photo AlbumsGarage
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-16-2007, 11:19 PM   #1
96 lt-4
CF Senior Member
96 lt-4's Avatar
Default comp cams xfi cam question
anyone out there running the xfi 466 or 467?
what rpm's and hp/tq are you getting?how is the idle quality and low speed/low rpm driveability?
i am not happy with the driveability on the custom cam i let the shop pick out for my stock w/bolt ons lt4.looking for proven setups with dyno numbers and/or timeslips.if you don't want to bare all feel free to pm me.
thanks,
george
96 lt-4 is offline   Reply With Quote
Old 11-17-2007, 08:34 AM   #2
96 lt-4
CF Senior Member
96 lt-4's Avatar
ttt
Old 11-17-2007, 02:47 PM   #3
Jonnymac
CF Senior Member
St. Jude Donor '08
1995 Chevrolet Corvette
Jonnymac's Avatar
Jonnymac is offline   Reply With Quote
Old 11-17-2007, 08:04 PM   #4
jonecap
CF Senior Member
jonecap's Avatar
Hotcam it and I'll hook you up with an OBD1 tune!
Seriously, are you thinking of changing out your cam?
__________________
'96 CE - LT4 Hotcam, 4.10 gears, exhaust, and a little nitrous...498rwhp/547rwtq
Best Nitrous pass (150 pills)
6.91.....1/8 mile
100.54...1/8 mph
10.75...1/4 mile
128.64..1/4mph
Best motor pass:
7.499.....1/8 mile
94.88...1/8 mph
11.650...1/4 mile
118.76..1/4mph
Motor only pass http://www.youtube.com/watch?v=4nF_Y5SVw-4
Nitrous pass
http://www.youtube.com/watch?v=ex98HEjZpWY
jonecap is offline   Reply With Quote
Old 11-18-2007, 02:03 AM   #5
Orr89rocz
CF Senior Member
Whats the specs on the custom cam you have now?
xfi 230/236 i have heard makes more power than the cc306 cam and idles smoother due to less overall overlap and 113Lsa.
Orr89rocz is offline   Reply With Quote
Old 11-18-2007, 08:14 AM   #6
pr0zac
CF Senior Member
1996 Chevrolet Corvette
Send a message via AIM to pr0zac
i have the 467 with some bolt ons in an lt4 and i would have liked to have gone bigger. i wouldn't say it idles smoother cause all you have to do is raise your idle. the 306 is larger just not in the lift area but the difference in lift isn't that much. i think the xfi's are meant to look big on paper but be a milder cam..
pr0zac is offline   Reply With Quote
Old 11-18-2007, 08:33 AM   #7
96 lt-4
CF Senior Member
96 lt-4's Avatar
the cam i have is 231/237@.050 on a 110* in at 106*.i can handle the idle but at anything below 2200 rpm it likes to surge and is'nt smooth while cruising.the car has been dyno tuned and it is better but not what i requested when we had the long discussion about cam choice.
i think the cam being ground on a 110 is the big problem.
chris-i am going to change the cam.it is a matter of when.the 467 is similar in duration and lift.i am looking for experience on the idle and how smooth the low rpm cruising is(1500-2000 in sixth gear).i think the 113 lsa might smooth it out enough.i want to be sure as i don't want to do this again.
Old 11-18-2007, 11:27 AM   #8
96lt4c4
CF Senior Member
96lt4c4's Avatar
thanks,
george
I am running the Comp 467. I have my car idling around 700 RPM now and it is kind of ruff. It was idling around 900 but I like to hear the cam lope a little. As far as low speed in 6th gear it does not like to run under 2000 rpm or under 60 mph in 6th. I usually have to throw it up into 5th. If I lug it in 6th I get some drive train clunking. Most guys say that is normal. My car still has a 3.45 gear so it may get better with 4.10s. I do not have any dyno numbers on my motor yet. I plan to take it out to a shop in Bowling Green KY in the spring and get it dyno tuned. See my sig for a video.
__________________
1996 LT4 383 All forged, Eagle 3.75 crank, Eagle 6.0" Rods, Mahle Forged Pistons, 11.0:1, Comp XFI 467, Ported factory LT4 heads, PAC 1518 Beehives, TFS Hardened 7.100" push rods, Comp Pro Mag rollers, Double Roller chain, Guide plates, Elec. water pump, Keyed balancer hub, TPIS Long tubes no cats, no resonator, Magnaflow. M/T ET Streets.
http://videos.streetfire.net/video/4...db00abc722.htm
96lt4c4 is offline   Reply With Quote
Old 11-18-2007, 02:18 PM   #9
Orr89rocz
CF Senior Member
i would agree. the XFI i have read from others experiences that its a good cam with decent idle characteristics and part throttle driving. A guy running that cam in his 383 is loving it. 383 will tame that cam down but it could work well with an LT4 with a good tune.
If not step down to a 224/230 XFI. it isnt listed in the catalog but they have it in their custom lobe catalog. they should grind it for you at regular price since its not a "custom" lobe, they have it in stock.
Old 11-19-2007, 12:38 AM   #10
pr0zac
CF Senior Member
i have 4.10's with a 355 but its still there.. it likes over 2 grand better.
Reload this Page comp cams xfi cam question
Tags
467, cams, comp, xfi
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Need camshaft advice for 383 LT1 MikePL C4 Tech/Performance 19 07-12-2005 09:29 PM
Advertise Here - Contact Us - Corvette Enthusiast Discussion Forum - Archive - Top
Powered by vBulletin
Search Engine Friendly URLs by vBSEO 3.3.2
