Digital Cluster...No Light
Old 11-05-2007, 12:16 PM
sr84
sr84's Avatar
Default Digital Cluster...No Light
Just bought a used cluster and every thing works but the tach which the person informed me that it didn't. The problem is everything is very very dim and can barley read it. The 3 directional bulbs do not come on, could this be my problem?
Or am I far off base or could it be other bulbs? Any input would help.
Thanks,
Mitch
Old 11-05-2007, 12:41 PM
vinnies87
vinnies87's Avatar
St. Jude '03-'04-'05-'06-'07
Use the search feature, this has been hashed 10000000000 times, all the info you need is there.
Old 11-05-2007, 12:44 PM
Bogdan
Bogdan's Avatar
I replaced all of the bulbs in my 86 vette cluster several years ago and this improved the clarity of my display. Cheap solution. I think I bought a light bulb kit from Eklers. I have read in the forum that you can also replade the standard bulbs now with halogen which run cooler to prolong the life of the display. Good luck.
Old 11-05-2007, 12:46 PM
sr84
sr84's Avatar
Thanks for the quick reply
To Digital Cluster...No Light
Quick Reply: Digital Cluster...No Light
