Rear Wheel Bearing Research CONTINUTED
#141
This is an old thread tapered roller bearings have been commercially available for C4s a while
now.
I bought a pair from when
Jr Rifle Coach did a group sale more than a year ago
So far so good
Here's a commercial provider
http://www.vansteel.com/index.cfm?fu...p=1906&ID=2977
now.
So far so good
#142
I read about a lot of different vendors selling rear bearing and I was wondering if anyone came to a conclusion on the best priced bearing for a car thats not autocrossed or raced for the most part. I will open it up sometimes, but thats rare. I also have the larger Grandsport replica wheels in the back that are really wide it that matters. I just ordered my VB&P rear suspension rebuld kit (trailing arms, strut rods, shocks, 12in lowering bolts, 26mm rear sway bar and toe rods) and dont want to tear down the rear again a few months later because of the bearings. I saw some on ebay but am afraid to buy anything until I run it by the Forum first.
#143
bearings
www.CORVETTEWHEELBEARINGS .COM$129 tappered bearings $110 stock. Made in U.S.A.
#144
Matt
#146
Has anyone run the bearings from Michigan? When I go to buy these things (I will have to buy two so they match) I don't want to buy the $200 ones if the $130 ones are working good.
#147
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
As for matched sets, well that must be a new spec. The old spec was to build all the bearings with identical runout. Cause when I received the order from MI, I packaged two bearings as they came out of the big box.
BTW I recall one CF member having a tapered fail inside 10K. Never did hear how his warranty worked out. Mine have over 25K and still seem quite...
#148
As best as I recall talking to the guy "from Michigan", he was the only mfgr of the tapered brngs for C4's. All the other sellers were buying from him.
http://www.vansteel.com/index.cfm?fu...up=202&ID=2975
#149
Failed Bearing
Warranty did not work out at all because you said you would get back to me but never did.
#152
has anyone else had any successes or failures on these wheel bearings? I am preparing a car for the road course and would like to make sure I put some components in that will hold up for some abuse. I understand changing them will be inevitable with this kind of use but don't want to have to do it every race weekend.
Thanks in advance!
Chris
Thanks in advance!
Chris
#153
Thanks in advance!
Chris
Thanks in advance!
Chris
#154
Thanks in advance!
Chris
Thanks in advance!
Chris
#155
Thanks in advance!
Chris
Thanks in advance!
Chris
#156
very cool, Please keep me posted guys. I just replaced mine with some units from Napa to get by and now i expect they may not last more than a month or so? they were a machined finish look completely different then the ones that came out.
If these fail i very seriously may redesign the entire rear knuckle for use with a different bearing larger stronger 40 spline spindle and coil over shock mount provision.
ack..
Chris
ack..
Chris
#157
#159
This was a fun GP.
Didn't know it was still around.
#160
First event last year was CMP, 2nd event was Road Atl.
With R6 tires the passenger rear bearing was done, shot, 2 pieces - no longer 1.
Put a set of NOS AC/Delco and so far (~20 events) they have not gone bad.
