Why is a simple smog pump becoming a project!
What a headache! The bearing went out in my 89 and started screaming. So, well, lets just say after a half dozen trips and 4 different stores I still dont have a pump. Seems the replacments come with way smaller and wimpier bolts and dont allow my pulley/bolts.
So I went over to Eklunds, there pump matches all the ones Ive been getting, and then has a note that it must be used with a a pulley that says its for a 86. Then in a small window is a picture of the 87-91 pulley, which is what I have. But that one doesnt work.
I know someone mentioned yanking the pump and theres a pulley replacement, but I have enough issues and dont need to add more codes etc!
I guess Im junk yard bound! Anyone else battle this simple issue? Oh, and the dealer says its discontinued. Great, thanks Chevy
Location: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Pull out all that air crap. Not worth the time.
Before you do anything, I just ripped mine out of my 90. If you want it, pay for shipping and I'll send you the entire mess.
The little black box, the pump, pully, bracket, everything.
It's sitting my my garbage pail, I'm traveling for work all week.
Let me know ASAP if you want it, or it goes out.
Again, just pay shipping and it's yours.
There are no Codes for the Air Pump but it does help light off the O2.
NAPA has a stocking # which is where I bought my last one, but that was a number of Years ago.
Couldn't find one at www.acdelco.com which is surprising given that these things are bread butter items for them.
You could try web searches at the other Discounters - Autozone, etc - take your pulley with you when shopping.
No codes and it doesnt affect driveability either. I took mine off earlier this year and all the wiring/tubing that goes with it. I left the pump on there and just tore out all the insides, lol. $150 for a replacement bracket is stupid.
Sounds good to me, this way I have some options. Send me a paypal addy and its on its way.
I did try Autozone first, they were getting one from the warehouse and never came thru. Then it was, Napa, dealer, advance auto, Napa again! Uggh! I would gut it, but I assume the pulley runs on a bearing right?
I'll pull it out of the garbage tomorrow.
I'll let you know what shipping is, just settle up later.
No it will not. At startup, it sends all the air to the headers near the head and during running it sends air to the cat, IIRC. I think that is the order. So, your O2 sensor is pre-cat and before it gets hot enough, the readings don't matter. So, even if it starts up and does or doesn't dump air into the headers, what does it matter?
When the car is warm, it dumps air out a tube with a round end. It's just a real PIA.
Once everything is working, I'm cutting those two wires short.
I wasn't sure about the order of the dump but if that were true, what does the pump send the air to? Not sure. It has been so long that the system "rusted away" that I cannot remember. I know it pumps air to the cat but not sure about the rest.
After the car warms up, it just dumps there.
Air pump is used (to this day, only the latest and greatest is spun by an electric motor) to help light off the O2 which gets it to Closed Loop. If you think it's efficient to run in open loop, do what some of the Ricer's do and cut the wire to the O2 and put a piece of tape across the Check Engine Light. After Closed Loop - and for the Earlier Years - air is redirected to the CAT where the afterburner effects eats up what's left of the HC's and CO. During Decel, when a bunch of fuel can enter the exhaust stream, the switching valve(s) pumps the air overboard, otherwise it'll backfire the mufflers off the car. Learn what it does and how it works and you may not find it so intrusive (or better yet, find something - other than electric propulsion - that eliminates it altogether. The OEM's will make you very rich).
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
If you remove the plumbing, you'll need some 1/2" NPT pipe caps to plug the smog tubes on the headers. I plugged the air tube on the cat by pounding a bolt into it.
