how much can I lower the car by removing the factory shims?
Re: how much can I lower the car by removing the factory shims? (95-383)
It depends on your car how much you can lower it by removing/moving shims. My car only had 1/4"-3/8" of shims. I know of one car that didn't have any. I don't think an inch is possible with the factory shims.
Re: how much can I lower the car by removing the factory shims? (Mr Dave)
You'll need some spring work to get that much. Also, I would use the shims that you get with the lowering kits. You won't loose that much (1/8"less lowered?) but it will keep the surfaces from impacting each other.
92TripleBlack :cheers:
Re: how much can I lower the car by removing the factory shims? (92TripleBlack)
Looks like Im gonna have to take out the spring to get it that low. thats gonna be fun :smash:. maybe Ill replace the spring with one from vette brakes that comes already with the lowering pads.
