94 LT1 ball joing replacement
Old 09-23-2007, 09:59 PM
grayml
grayml's Avatar
Default 94 LT1 ball joing replacement
Hello all,
Is there a procedure written up anywhere on the forum (or does anyone have a link) for the proper procedure for replacing the upper and lower ball joints?
Is this a DIY project or should I get a specialist to do it? If someone out there has done this how tough a job was it?
Thanks!!
Old 09-24-2007, 01:16 AM
BAM92
BAM92's Avatar
Upper not to hard, just becareful not to drill into aluminum arms when removing rivets. New ones bolt right in. Bottom you need a press. I dropped off the lower control arms at local alignment shop to press out and press new ones in. THey even said it was a pain. Saved a bundle doing it myself. I also did the bushings and polished up the pieces while I had it all apart.
Old 09-24-2007, 07:25 PM
JAKE
JAKE's Avatar
Several years ago I did the uppers and lowers on my 86. It was a first time for me. The uppers were a piece of cake, but not the lowers. I changed them with the arms on the car.
I borrowed the tool from AutoZone; it's free when returned. Removing the lowers wasn't too bad, but installing the new ones took all the muscle I could muster to press them in.
I finally realized - after struggling with one side - how critical it is to keep the new ball joint STRAIGHT during the compression process. So the second joint install went much smoother, but STILL called for a LOT of arm strength. Took an afternoon to do all four.
I believe someone posted to put the lowers in the freezer for a while to make the installation easier. I did know about that back then.
Jake
Old 09-24-2007, 07:57 PM
F1Fan
F1Fan's Avatar
Rent a balljoint press from an autoparts store. Mine took some creative arrangement of the different adapter pieces to get it to press the lowers in, but when they are straight, they go in without a whole lot of force. If they get the slightest bit crooked they'll bind.
Old 09-24-2007, 07:59 PM
pr0zac
pr0zac's Avatar
the lowers are way harder.. have fun.
Old 09-24-2007, 09:07 PM
Hotred94
Hotred94's Avatar
What joints did you all put in and what did they cost?
Old 09-24-2007, 11:03 PM
F1Fan
F1Fan's Avatar
I thought I'd bought mine locally, but I found an Ecklers receipt for $139.xx (+ $16.99 S&H), which came with all 4 ball joints and the outer tie-rod ends. They weren't Moogs, which is what I typically try to use, unfortunately just some no-name ones, probably some made in China crap. Also this was back in '05.
Edit: If you haven't done this before, this can be somewhat of a frustrating job, you may want to get some quotes for installs before you dive in. Also you will probably want an alignment if you replace everything.
To 94 LT1 ball joing replacement
Quick Reply: 94 LT1 ball joing replacement
