Timing won't stay set. Distributor moving?
Old 09-16-2007, 12:19 PM
rrubel
Support Corvetteforum!
rrubel's Avatar
Default Timing won't stay set. Distributor moving?
I've been checking my timing every couple months and I'm noticing that it keeps reverting to 0* advance. Not sure what's going on, but it's the third time this has happened over the past year.
- I'm making sure to check it with the timing wire disconnected.
- The engine is at normal operating temps (coolant/oil both over 150).
- The timing marks on the balancer are NOT slipping - I have a ~2 year old FluiDamper which is all one piece so the marks can't move.
- I have a non-stock distributor (Davis Unified Ignition)
Near as I can tell, the distributor is turning a little, but it always stops at the same place. I'm tightening the hold-down bolt as much as I can, but I'm afraid of breaking it so I'm not *REALLY* hanging on it. Also, it's not easy to figure the torque spec when tightening because of its location and the fact that I need to use an offset wrench to reach it.
This time, I marked the distributor and the plenum to see if it actually is moving; if that is the problem, anyone have suggestions on how to convince it to stay put?
Thanks.
[RICHR]
rrubel is offline
Old 09-16-2007, 12:29 PM
Muffin
Muffin's Avatar
I have never seen a distributor that was bolted down slip. Are you sure you don't have something very funky going on between your cam gear and distributor gear? I ran a bronze distributor gear for a short time. Couldn't keep the beast in time. Pulled the distributor,bronze gear was almost gone, worn so bad.
Muffin is offline
Old 09-16-2007, 12:34 PM
Pete K
Pete K's Avatar
Replace the bolt with a stud, and smear a little valve grinding compound on the bottom of the clamp, where it contacts the distributor.
Pete K is offline
Old 09-16-2007, 01:31 PM
rrubel
rrubel's Avatar
Hm. I honestly don't remember what material the distributor gear is made form. The cam has whatever Lingenfelter provides; I'd hope it's not bronze since they make high-performance/high stress items...
Pete, nice thought on the stud. I'll have to try that.
Car runs SOO much better when it's in time :/ .
[RICHR]
rrubel is offline
Old 09-18-2007, 12:47 AM
Dads90
Dads90's Avatar
I have a stupid question. Have you ever removed the distributor hold down bolt ? After a manifold gasket replacement I put the hold down clamp on upside down and the distrb. would not stay tight and would slip. Once I fliped the clamp I added a washer and it doesn't slip anymore. Just a thought.
Dads90 is offline
kenmohr (11-25-2019)
Old 09-18-2007, 05:27 PM
rrubel
rrubel's Avatar
Interesting thought; it's not a stock distributor and I *thought* I put the hold-down on right. I'll look at it again.
Thanks.
[RICHR]
rrubel is offline
Old 09-18-2007, 07:02 PM
SunCr
SunCr's Avatar
Sounds like the Balancer - Find TDC and see if the mark is still in alignment.
SunCr is offline
Old 09-18-2007, 11:15 PM
rrubel
rrubel's Avatar
No offense, but I stated initially that the timing marks can't move - the balancer is a single piece Fluidamper, not the GM rubber-mounted ring. Also, the car WAS out of timing. It runs a heck of a lot better now.
[RICHR]
rrubel is offline
Old 09-19-2007, 01:25 AM
John A. Marker
John A. Marker's Avatar
There is another possability....your distributor hold down bolt may be bottomed out. That happend to me and I'll be damned if I wanted to pull the bolt out and cut it off and fight to get it back in. Instead, I cut out a small section in a lock washer, backed out the bolt a little and slipped the washer around the bolt between the head and the distributor hold down piece. This gave me the additional clearance to tighten the bolt without bottoming out. The distributor does not move any more.
John A. Marker is offline
Old 11-25-2019, 04:40 AM
Chippos
2nd Gear
Chippos's Avatar
Default packing and moving companies near me
Packing and moving companies near me url g&j moving.
Thanks.
[RICHR]
how did you solve your question?
Chippos is offline
Old 11-25-2019, 05:52 AM
rrubel
rrubel's Avatar
I'm sorry; this was 12 years ago and I just don't recall now.
[RICHR]
rrubel is offline
Old 11-25-2019, 11:32 AM
TommyFox
TommyFox's Avatar
[RICHR]
Lol
TommyFox is offline
Old 11-25-2019, 11:56 AM
KyleF
KyleF's Avatar
12 year old thread... It could quite possibly have been the bolt bottoming out?
Something I didn't see in this thread that should be mentioned (if someone is searching these issues), is shimming the distributor shaft for end play. They sell kits for it, and basically if its loose the distributor gear can walk up and down the cam gear affecting the timing slightly.
KyleF is offline
To Timing won't stay set. Distributor moving?
Quick Reply: Timing won't stay set. Distributor moving?
