Rocking Chair Seat Syndrome Fix?
I vaguely recall reading a thread about this earlier this summer. I can't seem to find it in the archives though. :( Someone was going to take out their seats and see if they could determine what was causing the problem. Anyone figure out the fix? What does it take, cost, effort, time wise? Thanks. :seeya
Re: Rocking Chair Seat Syndrome Fix? (scorp508)
My driver seat rocks enough to annoy me. When I had the seat cushions out I grabbed the frame and yanked it a bit to make it rock and see where the play was. As far as I can tell, the slop is in the power seat tracks. The seat is firmly attached to the seat track and the track base is firmly attached to the floor. When I wiggle the seat there is definite independent movement between the upper and lower seat track parts. I put the seat cushions back on as I didn't feel like disassembling the power tracks at the time.
Re: Rocking Chair Seat Syndrome Fix? (dtorc4)
WTF are you talking about???? :confused:
Thanks for the feedback. :) I wonder if there are bushings or teflon guides something running in that track which are getting worn and which can be replaced....
Re: Rocking Chair Seat Syndrome Fix? (Juliet)
My 94 drivers seat did that. There are some bolts that go through the track hardware that were loose. You'll have to remove the seat to get to them. Be sure to fix them because loose seat bolts can strip and create more problems.
The C5's have this same problem. I even have the problem on my daily driver Honda Accord with electric seats.
Re: Rocking Chair Seat Syndrome Fix? (AquaMetallic94LT1)
Thanks AquaMetallic94LT1! As I said I ddin't remove seat frames to look at the tracks that closely. It's is good to hear that I can fix this easily! I'll get on it today before I do any more damage to the track.
:cheers:
Bob
:cheers:
Bob
Re: Rocking Chair Seat Syndrome Fix? (BobMachus)
Thanks for the fix! Bob, be sure to let us know how it goes. This is on my list of things to get to one of these days! :yesnod: It might only be a quickie job too.... Nah, nothing is ever quick working on the vettes! :D Thanks! ~Juliet :cool:
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
The seat rocking problem is in the main cross shaft at the front of the seat track. Over time they wear on the ends and this will result in play. The only fix I know for this is to replace the seat track. The seat tracks are all the same from 84-96. Right and left are different.
