Corvette Forum
Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-12-2007, 10:07 AM   #1
Greg Gore
CF Senior Member
Greg Gore's Avatar
Default A/C Service Port Schrader Valve Tool?
Anybody know where to obtain the tools to remove the schrader valves in the quick disconnect service ports on a 96 R-134A system? The high side valve core requires a smaller diameter tool than the low side. Located a tool to fit the low side valve core but have not located a source for the high side valve. Reason I ask is after adding R-134A I noticed both schrader valves leaking after disconnecting the couplers from the manifold gauge set. Thought I would check to see if they could be tightened a little before replacing them.
Greg Gore is offline   Reply With Quote
Old 09-12-2007, 10:43 AM   #2
runner140*
CF Senior Member
runner140*'s Avatar
Yes, any and all auto parts stores and any bicycle store.
runner140* is offline   Reply With Quote
Old 09-12-2007, 11:36 AM   #3
Bulldog Steve
CF Senior Member
Bulldog Steve's Avatar
Send a message via AIM to Bulldog Steve
The valves will leak (a few little bubbles) This is normal!
The caps have an O-ring inside to finish the seal..
Steve
Bulldog Steve is offline   Reply With Quote
Old 09-12-2007, 12:17 PM   #4
SunCr
CF Senior Member
The caps are to keep dirt out - they have nothing to do with the seal. If there are bubbles, you need to replace the schrader.
SunCr is offline   Reply With Quote
Old 09-12-2007, 02:26 PM   #5
Da Mail Man
CF Senior Member
Da Mail Man's Avatar
Steve
.....normal?..no it's not.....
Da Mail Man is offline   Reply With Quote
Old 09-12-2007, 02:26 PM   #6
Da Mail Man
CF Senior Member
Old 09-12-2007, 02:40 PM   #7
Tom Piper
CF Senior Member
Tom Piper's Avatar
For what it is worth, here is my opinion.
Even though bubbles are not a good thing to see at a schrader valve, there should be a good seal in the cap.
That seal in the cap should prevent leaking even though the schrader seal is not perfect, or you need a new cap.
I would put a new cap on it and put the schrader replacement on the list for when the A/C system needs major work.
I NEVER trust a schrader valve as the absolute seal -- regardless if it is a tire or the A/C system.
I consider the schrader valve as the mechanism to keep the "stuff" in there until I get a cap on it for a better seal.
Tom Piper
Tom Piper is offline   Reply With Quote
Old 09-12-2007, 02:55 PM   #8
SunCr
CF Senior Member
Ain't the design - in your car or home unit. You don't want dirt (or air for that matter) when you service the system. The cap is there to keep it out, and if you're **** about it, you use something like brake fluid cleaner before you attach the service hoses and once the can or drum is hooked up, you crack the connection (probably illegal) to purge air. Any leak, on the suction side particularly, needs to be dealt with. Most you don't see and the one's you do are larger than you might think.
Old 09-12-2007, 03:45 PM   #9
Greg Gore
CF Senior Member
Greg Gore's Avatar
All the replies are appreciated. Recharged the A/C this past weekend to tie the ribbons on finishing up a multi-part long term project and noticed both schrader valves bubbling just after removing the couplers. Thought I would check for tight first and bought one of those common combination schrader valve tools which has two sizes advertised to fit GM R-134A systems and only one size fit anything I have here, the low side. Am unable to check high side valve at the moment but the low side valve was tight; I might need to replace both valves. Incidentally, of my two original dust caps one is missing the internal rubber seal and I noticed a little pressure was released last night when I removed them again to check to see if the newly obtained tool would fit the schrader valves. I checked GM part numbers and apparently the dust caps are only available with the lines. What to do?
Old 09-12-2007, 03:54 PM   #10
STL94LT1
CF Senior Member
STL94LT1's Avatar
Send a message via AIM to STL94LT1
Greg, you can buy a kit containing the caps, small shraeder valves, and tool at AutoZone for around $6.
__________________
2001 White/Black/Black Vert M6/Z51: LPE TT650 580rwhp/540rwtq
1994 White/Red M6 LT1 Corvette: 374rwhp/345rwtq,12.37@119: Heads/Cam/4.10's
2001 Ford Lightning: 425rwhp/503rwtq,12.85@108
2006 Cobalt LS (DD)
STL94LT1 is offline   Reply With Quote
Old 09-13-2007, 08:50 AM   #11
Tom Piper
CF Senior Member
Tom Piper's Avatar
For this price, you probably could replace the entire system, but here it is.
http://www.jcwhitney.com/autoparts/P...017926/c-10101
Tom Piper
Old 09-13-2007, 09:02 AM   #12
Muffin
CF Senior Member
Muffin's Avatar
Quote:
To get back on the subject: Auto parts store. Don't think those sold in bike shops have sufficient reach.
Muffin is offline   Reply With Quote
Old 09-13-2007, 09:26 AM   #13
Da Mail Man
CF Senior Member
.....a few months ago, i discovered a high side shrader valve leak
(r-12) .....the high side shrader is a smaller valve and on my 88 it is RECESSED a lot farther into the bore......i purchased a master kit and discovered that the shrader tool i already had could remove the low side valve no sweat but, didn't fit the high side valve bore in DEPTH as diameter was fine.....the master kit was useless.....so, those seeking tools be careful that the hight side (r-12) extractor fiths the DEPTH of the bore!...since i own reclaim/recovery machines i removed the refrigerant and extracted teh valve core with a pair of tweezers and replaced, vacuumed, rechared and good to go!
Old 09-13-2007, 12:19 PM   #14
ineVETTEable
CF Senior Member
ineVETTEable's Avatar
I recharged my r134-A and when I removed the manifold kit my valve leaked bad. Actually sprayed. I couldnt get it to fully close, so rather than loose all freon I chose to just screw the cap on and let it go till it nolonger blew cold air. That was in spring, still got cold air.
The moral of the story; the cap does have an oring seal. That seal works really well under most circumstances. I don't think a few bubbles a minute is enough to worry about. Finally when it stops blowing the cold...change the valves and recharge.
ineVETTEable is offline   Reply With Quote
Old 09-13-2007, 12:38 PM   #15
Greg Gore
CF Senior Member
Greg Gore's Avatar
Thanks to Tom Piper for the link to the valve core service set. I wonder if this one will allow changing the valve without losing the charge? Muffin is right about standard schrader valve tools not reaching. The schrader valve cores in A/C systems are recessed more than conventional tools will reach so you need a longer reach tool. Also, the high side on mine is in a smaller bore than the low side valve so the tool to service GM high side valves needs to be smaller diameter than the low side tool.
Old 09-13-2007, 06:59 PM   #16
Da Mail Man
CF Senior Member
Quote:
....i though i just said that?.. ....they make tools to remove the core W/O losing the charge but, like i said before, you will need a VERY long extractor to pul the shrader valve on the high side (R-12)....below is for the LOW side...
Click the image to open in full size.
Old 09-13-2007, 10:24 PM   #17
Greg Gore
CF Senior Member
Greg Gore's Avatar
Oops... Sorry about that DaMailMan! You are correct; I meant to acknowledge your info but brain faded I guess. The tip is appreciated.
Update:
I was mistaken about the high side valve on my car. Upon closer inspection I see now it is actually not a schrader valve but rather a small rubbery composition ball of some kind in an inverted seat. I pecked at it a little and it stopped bubbling. I can't say for sure if my high side line is OEM or not but I think it is. I found some new plastic caps with seals at NAPA so maybe I am OK for a little while at least. I guess if the charge is eventually lost again maybe that would be a good time to revisit the service port valves. Thanks to all who contributed!
Old 09-14-2007, 06:16 AM   #18
Da Mail Man
CF Senior Member
Update:
...no sweat!...just busting your chops a bit
Old 09-14-2007, 06:50 AM   #19
Tom Piper
CF Senior Member
Tom Piper's Avatar
....I was mistaken about the high side valve on my car. Upon closer inspection I see now it is actually not a schrader valve but rather a small rubbery composition ball of some kind in an inverted seat. I pecked at it a little and it stopped bubbling. I can't say for sure if my high side line is OEM or not but I think it is. I found some new plastic caps with seals at NAPA so maybe I am OK for a little while at least. I guess if the charge is eventually lost again maybe that would be a good time to revisit the service port valves. Thanks to all who contributed!
Interesting it is a ball valve instead of a schrader.
I seem to be in the minority here, but I have found the schrader valves are a poor ultimate seal -- notice how many others on this thread have said the schrader valves have leaked. It is common.
That is why I wouldn't get excited about just putting a new cap with a new seal on and let it that way. If the cap has a good seal, it will do the job in spite of the schrader.
As I stated before, to me the schrader is nothing more than a convenient way to keep from losing the charge until you get the valve cap on for a better seal.
The valve cap does keep out dust, but it has a much more important job.
Tom Piper
Old 09-14-2007, 09:25 AM   #20
Da Mail Man
CF Senior Member
Tom Piper
.....humnnn...ok, what happens when you have 200+lbs of pressure on a high side?...ya think the cap will keep it in or even stay on?...
Reload this Page A/C Service Port Schrader Valve Tool?
Tags
ac, air, c4, charging, conditioner, core, corvette, gm, high, leaking, scharder, schrader, side, tighten, tool, valve
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Walmart A/C 134a Retrofit kits (Interdynamics) snoopdan C4 Tech/Performance 34 04-29-2005 05:11 PM
R-12 to R-134A Sprout C4 General Discussion 22 03-25-2005 12:57 PM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
