Am I wasting $120.00
I was getting ready to take my intake off this weekend when I told by a mechanic who is pretty respectable not to do a thing until I got a system print out from a computer scanner like the dealers use. I tested a lot of the components in my 84 with a volt meter and all seemed with in specs and I thinking its a vacuum leak even though I cant find it. It runs about $120.00 to get the scan done. Do you think I'm wasting my money?(This car has a extremely fast idle)
if you go to a auto parts store autozone advanced auto or so on ya can buy a scanner that will give you the codes off your car and should be able to get one less then that guy is charging and get more then 1 use out of it. believe me it comes in handy. it should come with a book with the codes or ya can use the codes from an fsm. like mentioned above the fsm will give you directions to do it with a paper clip. this info is also at the crossfire injection forum as well. the $125 fee does sound a bit high but not by much. it is only a waste of $ if ya have capability, know how, and means to do it yourself. i do agree ya should pull the codes to see what if anything comes up.
Last time I had my other car scanned it said, Transmission defective, replace entire unit. Didn't tell me anything an idiot didn't already know. The guy actually had the nerve to ask me for $60 for those 5 words. I took it to another shop for repairs.
save your money and just go get a paperclip or short wire and use that to read your codes.
I haven't read all your posts between here and the cf forum. I do know you have the xram, have you check your plenom gaskets? TBI gasket. I would think if your gonna spend over a hundred bucks the TBI rebuild kit would be a better purchase, just my 2 cents
Corvette Enthusiast
As apposed to getting the scan done at the dealer, you may want to download WINALDL (it's free) and purchase a cable from the site link for around $60. This will allow you to connect to your OBD1 and read the codes yourself with a laptop as well as see your sensors outputs just like the dealer system will do.
Here's a link to the Winaldl site for the software,
http://www.aldlcable.com/
Here's a site for the cable if you don't want to build it yourself.
http://winaldl.joby.se/
Another few things you may want to try is capping the vacuum ports on the CFI intake to see if you have a vacuum leak on one of the lines, and re-tighten the bolts holding down the intake lid. They are known for coming loose and causing a vacuum leak.
One more vacuum line to check that is a very common failure on the 84 is the vacuum line that comes out beside the distributor, on the manifold and connects to a check valve splitter to feed the dash vents and the cruise control / vacuum canister.
I built a cable and downloaded the program for use in my '85. It provides everything you need to know about your car. Total $ I spent was about $4 for a few transistors and resistors.
Yes $120 is a waste when there are so many alternatives....buy a good scanner...borrow a good scanner....buy a FSM....join a local Corvette group and get someone to scan if for free.
