Stealth ram Stroker #'s
Planning on running my stealth ram on a 388 and just wondering what kind of numbers do people have with this intake and strokers?
I know about the clearance issues and and have looked at ld85's pics alot. but i also like the look of the riser hood so im not sure if i should make it clear the stock hood. As in ld's detailed account i believe he has done some things to make it flow better and would like to implement those ideas. i was hoping around low 12s to high 11s but a higher stall and maybe a dana 44 would be in order before something blows up.
Very nice John,, routing the wire looms and plug wires is not a big deal,, I see you have a NOS setup, I may have to pick your brian after I get back from the track in mid Septemeber.
Not a stealth ram but close. My 91' Vette with the destroked 400 block=370ci ran a best of 11.7@121MPH with a crappy 2.2 60ft. Makes 440rwhp with a small 236/236 solid roller cam. I just bought a CCW drag pack so I'm hpoing for a low 11sec pass with a good 60ft...My intake was portmatched to my Brodix heads as well..I also am running the 1300cfm monoblade throttle body..Built the motor myself in my garage at home...
boost however is a different animal...and at 10:1...you'll be lucky to get maybe 6psi non-intercooled before massive failure
10 to 12psi of boost with an intercooler can be done pretty easy with 10/1 compression...Static compression isn't as important as dynamic compression is when it comes to boost. So it really depends on the valve events of your cam...
and i didnt know if you would be intercooled or not...an intercooler makes all the difference in the world...typically 6-8psi non-intercooled at that compression level is about it...more if intercooled/built motor/correct cam choice/etc...
my friend found out the hard way with his 10psi non-intercooled on his LS1 camaro
