Should I remove Fuel Vapor Can and relay
Old 07-06-2011, 08:51 PM
ibonzi
Cruising
ibonzi's Avatar
Default Should I remove Fuel Vapor Can and relay
Again I want to clean the mess up. Removing the VAP Can and relay bad? Also had to remove the EGR tube from the exhaust as it was rusted through which means the EGR wot work right? So it might as well hit the trash? Anyone had a problem with this? TPI sells all the block off plates. Just sent the TPI,valve covers and misc brackets for powder coating AND ordered new Bosch IIIs from FIC......cant wait.
Old 07-07-2011, 04:04 AM
rodj
rodj's Avatar
Would still need a breather on the tank somewhere where fumes won't be drawn back into car.
Old 07-07-2011, 10:11 AM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
Vent the fumes out the roof scoop.
Old 07-07-2011, 10:30 AM
engle1147
Support Corvetteforum!
engle1147's Avatar
Great pic of the paint on your ride!
Old 07-07-2011, 10:51 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Fix it and make it work right.
Old 07-07-2011, 08:23 PM
impact1968
impact1968's Avatar
If you use a vented gas cap you can toss everything.
Old 07-08-2011, 08:43 AM
C409
C409's Avatar
........... Just keep in mind that fuel vapors are most explosive ............
To Should I remove Fuel Vapor Can and relay
Quick Reply: Should I remove Fuel Vapor Can and relay
