Brake bias spring and prop valve
I have a 95 base coupe. I was installing a new brake bias spring and brakes. When I removed the end cap on the master cyltinder, I did not find the "electrical brake bias spring" under the end cap. The combination valve had the spring, but in between the cap and combo valve there was none. Both the shop manual and the instructions that came with the new spring indicate this spring should be there. Any info would be greatly appreciated.
That spring is real thin, maybe someone else left it out.
The problem is with a missing spring that should be under the end cap before you would take out the combonation valve assembly. There was not a switch problem. If any one could describe in detail this spring or show a pic with something beside it for size, maybe I can make my own spring. I think it is just a ground if you would lose brake pressure at either end of the car. When the valve slides this keeps contact with the body thus providing ground. I could be totally wrong though.
I can take a picture of that in a few mins. The end cap spring is very fine wire, it hardly has any spring to it. I like your idea of it making a ground path, though I do not know for sure. I will post you a picture in a little bit, I have a spare M/C in a box with the end cap loose. Both the old and new M/C I have, have the spring.
Here you are, picture one in the bore:
The spring outside, it has no spring to it at all.
Wow, Mine did not have that spring, but my end cap has a non threaded part below the threads that would probably take up the amount of space the spring would. Maybe a 1/4 or 3/8 of an inch. The other thing I see is that your combo valve is in the bore in the opposite direction as mine was. The end I see in your picture was towards the firewall on mine. That is the forward side of the MC in your pic, right? This is making me nervous. Thank you for your help.
My combo valve may not be in there correctly, I did not check. The brake warning light switch is not installed though.
OK. I think mine is installed correctly according to the FSM. Just curious, what year is yours? Our end caps are different and I wonder if they have replaced the spring with the shoulder on the end cap. Although I am not sure what the shoulder or the spring are suppossed to do. They call it an "Electrical bias spring" that is why I thought it might be ground for the valve since the valve rides on the O-rings. Thanks again.
I have two M/C here, both from my '88.
