Difference between a LT1 cam core and traditional SBC cam core?
Old 07-31-2007, 02:42 PM
5abivt
5abivt's Avatar
Default Difference between a LT1 cam core and traditional SBC cam core?
WHat's the difference between a LTX specific cam compared to say an L98 or traditional SBC cam core ?
Old 07-31-2007, 03:20 PM
billvh
billvh's Avatar
I think the only difference is the LT1 has a drive pin in the front which can be removed.
Old 07-31-2007, 03:50 PM
5abivt
5abivt's Avatar
So it's just the drive pin, which I believe is for the water pump drive?
Old 07-31-2007, 03:56 PM
STL94LT1
STL94LT1's Avatar
Nope, the LTX water pump is driven off the water pump drive shaft, which is driven off the upper timing gear..
On the 95/96 LT1, the pin drives the opti. On the 92-94 the opti is driven off a splined shaft that inserts into the upper timing gear.
Old 07-31-2007, 04:01 PM
hippy
hippy's Avatar
The difference IS the pin length and for a Gen 1 block you cut that pin's length I believe in half. It's been a few years so I don't exactly remember the length you cut it to, .375" kinda rings a bell.
Old 07-31-2007, 04:13 PM
89onlyZ51
89onlyZ51's Avatar
The cores are the same (meaning bearings and lobe placement). There are some subtle differences that will vary from cam to cam - distributor gear, fuel pump lobe, and the dowel pin already mentioned.
Old 07-31-2007, 04:45 PM
5abivt
5abivt's Avatar
Ok because COmp cams will not custom grind an LTx solid roller cam, but have a 4/7 swap available for a traditional sbc. Im using an electric water pump and no optispark so a regular sbc cam should work fine. Thanks for the input !
Old 07-31-2007, 04:48 PM
5abivt
5abivt's Avatar
Right on thanks. i forgot all that jazz since i removed my opti/waterpump etc like 7 years back
Old 07-31-2007, 06:35 PM
hgh pwr
hgh pwr's Avatar
have someone else grind you a cam,doesn't have to be comp.
Old 07-31-2007, 10:16 PM
BlackC6LS3
BlackC6LS3's Avatar
How about sharing some pictures and information on how you got rid of the opti.
Old 08-01-2007, 11:14 AM
MSR
MSR's Avatar
whoa! it doesn't matter to you since no more opti, but for future reference when other people do a search:
the late opti requires the LTx core. the LTx core has a large hole bored into the nose. the opti shaft goes through the cam sprocket and into the cam's nose.
-michael
Old 08-03-2007, 09:11 AM
rodj
rodj's Avatar
Be aware a cam for a regular SBC (retro roller cam ) will require a cam button to hold it in as the L98 / LT1 cams has a machined recess on the front for the cam retainer plate.
To Difference between a LT1 cam core and traditional SBC cam core?
Quick Reply: Difference between a LT1 cam core and traditional SBC cam core?
