Turbo 400 Question for Pete K
My 700r4 took a dump or is about to and I have a rebuilt 400 sitting around...since I don't plan to go 100+ mph and the engine is carbed so overdrive is'nt important to me...would realy like to get away from the TV cable stuff anyway..I know the drive shaft will have to be shortened but what other snags are there
Tail housings will not swap, so I presume you would have to fab a crossmember to the c4's frame, then some kind of torque arm from the crossmember to the crossmember would need to be fabbed.
Hopefully, someone who has done it will chime in.
I plan to have a less expensive(hate the word cheap) trans availble for sale in the next week or 2, if that helps.
Apparently, a spacer moves the tailhousing to the proper position, allowing it to bolt directly in. Zero fabbing.
Ski_Dwn_It ran a turbo 350 for a while, and I am sure he would be helpful with some other details.
Although the tv cable is a pain in the azz, I have always been a fan of the 700. The killer 1st gear and overdrive have kept me loyal. @ $3.50 a gallon for fuel, I plan to keep mine for a while.
RACE ON!!!
Location: 2003 Points Champ Great Lakes Corvette Challenge; 2006/2007 Winner MSD True Street
1 Post
While neither of the Turbo Hydro transmissions, mentioned, have a TV cable, the TH350 does have a "kick down" or detent cable. The TH400 uses an electric kick down and therefore would require a switch added onto the throttle linkage, somewhere. Just a tidbit for further consideration.
RACE ON!!!
RACE ON!!!
T400 has an elctric kick down and require a switch added onto the throttle linkage?
Matt383
1 Post
But I do have a T400 in my vette.
I have been in the shop when my trans was on the bench during a refresh.
All shifting and shift points are regulated by a governor (spinning weights/springs) and valve bodies (I asked a lot of questions) as I was trying to get my 1-2 and 2-3 shift dialed in.
This process was a trial and error thing until we got it right, by playing with the weights on the governor.
So I settled for getting my 1-2 shift perfect and I use a shift light for my 2-3.
Anyway, I was going to shoot my mouth off by saying that there is no electric switch until you mentioned the Skylark....
This brought back the foggy memory of a 72 cutlass I drove back when I was 16 years old. It got stuck in first gear and I had to play with cable under the dash connected to the gas pedal.
Seeing that the Buick and the cutlass were almost the same car I now can see the reason for your your explaination.
Must have been some sort of design thing they tried for a few years on those cars as I have not seen it since.
Matt383
Originally Posted by Matt383
Now I am not a trans expert.
Matt383
1 Post
OK.
Now this is the thing.
My t400 is 1963 tecnology basically.
No electric anything.
All done mechanically... upshifts and downshifts.
wieghts, springs, valve bodies, etc.
So where is Pete K when you need him??
Matt383
Matt383
Matt383
Matt383
All of mine have all that you mentioned PLUS the vacuum modulator AND the electric kick down.
PETE!!!
RACE ON!!!
1 Post
[QUOTE=CFI-EFI;1561290571]No fair. I asked first.
1963??? I don't remember the first year of the TH400. I was thinking it was a couple of years later than that. One of the first was the Buick (exclusively) with the "Switch The Pitch" dual stall torque converter.
QUOTE]
1963..figure of speach as in old as heck. I actually think the first year was 1964 so you may be right on that.
Anyway, funny that you mention the buick.
I had to go to an old Buick yoke (1965?)
It took a larger bushing (Diameter) and was longer. (went further into tailshaft housing) for better strength and balancing.
Also, I found this bit of T400 research:
the TH400 was the first three speed, Simpson-geared automatic to use overrunning clutches for both first and second gear reaction, a feature that eliminated the need to coordinate the simultaneous release of a band and application of a clutch to make the 2-3 gear change. Owing to this feature, as well as the use of a large, multiplate clutch to provide second gear reaction, the TH400 is able to withstand very high input torque and an enormous number of shifting cycles, as would be encountered in frequent stop-and-go driving. As a result, it has met with considerable success in commercial vehicle applications.
For 1987 GM changed the nomenclature of their Turbo Hydramatic transmissions — the THM400 was renamed to the '3L80' (3 forward speeds, longitudinal positioning, and an arbitrary 'strength' of 80, the second highest such rating assigned). The 3L80HD was introduced in 1987 as the HD unit used in passenger trucks. In 1992 a 4-speed overdrive version, the 4L80-E, replaced the THM400 in Chevrolet/GMC pickups, vans, SUVs, and commercial vehicles. The 4L80E (and its successor 4L85E) was the first Hydramatic to incorporate electronic controls Matt383
QUOTE]
Every 400 (or turbo 375) I have come across does have an electic detent. If there are versions that do not use electric detent, I am unaware of them. The ATSG manual also makes no mention of non electric detent versions. I have always "presumed" they were all the same in this regard.
1 Post
I stand corrected.
Thanks Pete
Matt
There ya go.
I stand corrected.
Thanks Pete
Matt
I stand corrected.
Thanks Pete
Matt
RACE ON!!!
RACE ON!!!
