Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 07-25-2007, 12:12 AM   #1
Kinkajou
CF Senior Member
Kinkajou's Avatar
Default Overflow at power steering fluid reservoir... turn one pump installed..
After some problems at a TD y changed the PS pump with one modified by Turn one steering.
After some hot laps I realized that there was some smoke coming from the engine bay. When I opened the hood I noticed that the problem was due to some power steering overflowing from the reservoir.
I thought that the Turn one steering pump would reduce the presure enough so this would not happen.
Are you guys having this problem?
Do you have any suggestions to avoid this from happening?
Could this mean that I will have problems eventually?
I am really confused here and have a Track day this Saturday and I am afraid that something could go wrong.
Please advice, thanks guys!
Kinkajou is offline   Reply With Quote
Old 07-25-2007, 01:40 AM   #2
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Are you sure it's overflowing, not just foaming up and coming out the little breather hole in the cap?
What fluid are you running. I was using Mobil 1 ATF and it foamed up easily. Went to Valvoline Synpower and have been better off since.
Also, if the suction hose is leaking the pump will draw air in here. If you aren't 100% sure this hose is good, change it. GM part only, about $30.
CentralCoaster is offline   Reply With Quote
Old 07-25-2007, 01:41 AM   #3
CentralCoaster
CF Senior Member
Underdrive crank pulley would help too.
Old 07-25-2007, 10:46 AM   #4
jakers
CF Senior Member
St. Jude Donor '06
jakers's Avatar
Default Synpower
Try the Synpower
jakers is offline   Reply With Quote
Old 07-25-2007, 11:43 AM   #5
Kinkajou
CF Senior Member
Kinkajou's Avatar
I am sure it is not foaming because I took a look inside of the reservoir and was ok.
I am actually using the GM fluid recomended by the manual.
Steering feel is good, no problems there, but the idea of an overflow makes me nervous because it might mean that the pump is still working at a lot of pressure.
Ideas on what to do?
Old 07-25-2007, 11:52 AM   #6
MSR
CF Senior Member
MSR's Avatar
it's not overfilled, is it? also, could it just be the seal on the cap? i've seen some where the spring and/or seal deteriorated and sloshing would easily leak out.
also, do you have a cooler?
-michael
MSR is offline   Reply With Quote
Old 07-25-2007, 11:10 PM   #7
Kinkajou
CF Senior Member
Kinkajou's Avatar
Yes, i have a cooler and the reservoir was not overfilled.
Will check the cap, it is a good idea. Thanks
Old 07-25-2007, 11:25 PM   #8
CentralCoaster
CF Senior Member
If it's not overfilled, then there is no possibility of it expanding that much to overflow. It has to be either boiling, or drawing air in or otherwise foaming. Does it make any groaning noises when you drive it hard for awhile at high RPMs? The groaning is the sound of air or vapor pockets hitting the pump impeller, and will damage it eventually.
Old 07-26-2007, 11:57 AM   #9
Kinkajou
CF Senior Member
Kinkajou's Avatar
Quote:
CentralCoaster Does it make any groaning noises when you drive it hard for awhile at high RPMs? The groaning is the sound of air or vapor pockets hitting the pump impeller, and will damage it eventually.
PS Pump and Gear work fine. It is that when driven hard ( 120 +) there is some smoke coming from the passenger side due tue P S fluid that gets out of the reservoir.
I read somewhere else that some forum members were using some kind of overflow tank, but I can't seem to find the posts.
Any idea on this kind of modification?
Reload this Page Overflow at power steering fluid reservoir... turn one pump installed..
Tags
corvette, fluid, overflow, overflowing, overflows, power, pump, pumps, reservoir, sloshing, steering, turn, turning, turnone, wheel
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
