When is the weather to cold for a 160 thermostat?
Thinking of doing this, but not sure if it would be good for the engine in the winter? It can get pretty cold here, down in the teens. Will it hurt anything when it's that cold?
Re: When is the weather to cold for a 160 thermostat? (jay17)
I have one in my car, and we've see 0 now and then. :) The car takes a little longer to warm up, but once it does everything seems fine.
I ran my car all year around with at 160 for 4 years in Jersey weather without a problem.
Extended driving at low water temperature is bad. See my post below for consequences of driving with a cold engine. There are reasons why the SBC is usually fitted with a 190-195 degree thermostat. Those who think that running the engine cooler will result in longer engine life and increased performance are mistaken. http://www.enteract.com/~mikew/ubb/F...ML/001046.html
Location: Almost all Skyline Cruises Vettes at Waterside 1-5
1 Post
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Thermostat only controls when water flows from radiator, not if it will.
Point of illustration: I run a 180 in the vette. Last weekend on Skyline cruise, in the mountains, water temp stayed in the high 160's. low 170's. Thermostat remained closed, so would have a 195 or 200 degree thermostat.
So thermostat does not control minimum engine temp, only the point where the thermo will allow water to flow from radiator to cool engine.
I disagree with running engines hot and I have four SBC with a collective 700,000 miles without even the heads off for valve work ( 3 Z 28' and the Vette) I keep my engine temps in the 160-180 range and change oil every two months
Keep it cool ;) Heat kills!
:seeya Jack
:seeya Jack
Re: When is the weather to cold for a 160 thermostat? (jackdaroofer)
totally agree with jack, i run a 160therm year round & when i pull the engine up on diacom, like i did yesterday, even with 50deg temps outside the coolant was right at 170deg..perfect
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
snip
:seeya Jack
snip
:seeya Jack
With the 160 stat combined with better fan control I've yet to go over 190 in bumper to bumper traffic at 90 plus in the summer. Compare that to people running 235 - 240 with the stock thermostat.
I wish I could find the graph that shows wear in a small block chevy vs operating temp.
I think there is a lot of confusion about what people mean when they say running it cold. Essentially the only wear you will get that is any worse than any other time is at startup. Allow the oil time to get going before you go WOT. Other than that there shouldn't be much difference in how warm it gets. I have to agree with keeping it as cool as possible as it does make more power. The excessive heat is just for emmisions purposes, but bad on everything else.
As it has been stated above a 160 thermostat alone will do VERY little as far as keeping the car cool in traffic. The temps will still soar like crazy unless you have the fans programmed to take advantage of it. My car always runs at 178 with the 160 stat and the programmed fans. To me this is a very comfortable number. Not too hot.
1 Post
Cruise-In I Veteran
Cruise-In V Veteran
Re: When is the weather to cold for a 160 thermostat? (AquaMetallic94LT1)
snip.
You thermostat or temp gauge are out of calibration. Your engine should not go below the rated temp of thermostat, unless outside temps are very cold. If a thermostat stays closed the engine over heats.
Response: I agree, if the thermo stays closed when the water temp in the block exceeds the thermo rated temp, it means two things...1) your thermo isn't working and therefore 2) your engine will overheat. That's true whether you run a 160 or 195 or 225 thermo! As to my stuff being out of calibration, doubtful! Many Vettes with 195's run in the 180's on the highway, are they all out of callibration?
I wish I could find the graph that shows wear in a small block chevy vs operating temp. [/QUOTE]
Response: And I would invite whoever made the graph to come to my garage :D :D
Heat kills ;) ;)
:seeya
Jack
Heat kills ;) ;)
:seeya
Jack
Re: When is the weather to cold for a 160 thermostat? (tntcorvette)
it takes too long for the oil temp to warm up in cold weather with a 160 stat. So if you use one, make sure the cooling fan wont kick in until ~200 or so
Re: When is the weather to cold for a 160 thermostat? (scorp508)
I use Mobil 1 5-30 oil, & have a 160 thermostat.. last year in -10 deg weather I drove to NJ .. the engine temp stayed right at 170 but the oil temp was 190... trans temp 175..
Agreed you do not get REAL HOT heat, but I did not need a jacket .. It was very comfortable.. As far as I'm concerned the only problem is it takes longer to get the inside of the car warm..
Oh also I do drive very easy (under 2500rpm) until oil is 150 deg.
Can you run a 160deg t-stat with the stock chip?
If not, what would the optimal fan settings be?
Thanks,
btw, when I first bought my Vette in '95, the temp would run around 165-175. I had taken it to a dealership to fix a coolant leak and asked them to check the t-stat cause I thought that it was sticking. They just went ahead a replaced it with a stock t-stat. This was all before I knew anything about performance mods on a Vette. Could my car had a 160 t-stat in it when I bought it? hmmm....
Thanks,
Re: When is the weather to cold for a 160 thermostat? (JQ87)
