Remove My Membership Please Thank You
You know...I just looked thru a number of your posts. I am not your first victim apparently. You insult on the regular. No wonder you race a stock 1984 C4. Wanna race?
I know my time on CF is limited.....but I'm going down swinging cause I had enuff of you types. Learn to correct and reference materials that you think is incorrect...rather than insult.
CFI EFI may be harsh, but I'd rather have him giving out good info than a nice person wasting my time and money. Something else, one obvious rule of the forum(and not being an a-hole) is don't insult other people's cars.
Also, you look like a tool in that photo.
Whoa. Calm down.
BTW, you see none of this nonesense on the F-Body forums
....ok...this is my last post on CF...I shrink to observant status. Still love my 1996 C4 and a lot of you guys. See ya around and don't forget to wave!
I agree. That's why I spend most of my time on F-body forums. On most of those forums they don't tolerate idiot noobs posting bad tech info, and they sure don't tolerate idiot noobs who post bad tech info and then post insults when called on it.
-- Joe
Snowmaker, please understand, some have a short tolerance for perpetuated mis-information.
Do you want some one to nicely tell you the wrong info?
Not me, I'd rather hear the nasty truth so I can make a rational and educated decision.
Me being hard headed may question a member like CFI, hence I get what I deserve.
Those that don't like me or don't care about me would just allow me to go on believing incorrect info. That my friend would be hurtful.
So you agree that name calling is appropriate? Why can't someone simply say, you are incorrect and then give you a verifiable reference to correct information. Look what happens to people new to the forum. It is shocking.. BTW, I know I wan't suppose to post anymore, but I cant help it. lol...No one can tell me that coolant running thru the GM TB is to prevent icing. Its nonsense. Thats why fuel injected AIRCRAFT do not have carb heat. There must be another purpose.
Originally Posted by snowmaker2000
you are a butt hole....
go to hell
imbeciles on CF
put some Mobil One on that hand....and shove it up your . . .well you know where.....
#33
Thats right....I insult people back when they insult me first. . . I'm obviously not happy with being attacked and then being dictated to and being called all sorts of names...FIRST (I guess you forgot to put those posts up eh?). And then have people ah hem...like yourself back that garbage up . . . . .and I must add since you wanted to chime in for unknown reasons......you apparently are an a-hole yourself for trying to put together propaganda.
#34
aaaa..... there is no gas in the throttle body, or plenum for that matter. I was told the reason was for cold start emmissions, and extreme cold weather driveability. But it sure doesn't help much im Phoenix!
No I think he's right about the TB heat. But it's no reason to insult someone. GM started running coolant throgh the throttle bodies in TPI (tune port injection) engines found in some camaros and corvettes in the late 80s. The purpose was to keep the gas from freezing in the throttle body in extreme cold conditions. It was considered by most people to be a pointless addition. Many people choose to bypass the throttle body, but dynos prove that it really doesnt help performance at all to bypass it, because the air is moving through the throttle body too quickly to heat the air. Personally, I would leave it alone if you live in a cold climate.
#36
Page 6C-2 of a 1985 Factory Service Manual,(first year of this style TB) says...
"Engine coolant is passed through the throttle body to prevent throttle icing"
If you have problem with that, please contact Gordon Killebrew for further discussion.
Good luck in your searches for information, and remember its people like CFI that will be the reason the thread ends with the right info. It's OK if you don't post thank you's in the future, the point is to help without needing a pat on the back so just let it be said here..
"You're welcome"
#37
I think we were both wrong on that one. TB freezing could be a problem in very cold climates. Cessnas have carb heat. If the carb freezes it gets no fuel. Sorry, got my wires crossed on that one. I reverted to ground school for an quick answer. Should not have posted without rereading. We all make mistakes.
#38
I didn't know I could do that. Hmmm, I still will not post tech stuff anymore... besides, a Chevrolet dealer tech just moved to my neighborhood. I'm going to ask him about the TB coolant issue in the morning.
#39
No I think he's right about the TB heat. But it's no reason to insult someone. GM started running coolant throgh the throttle bodies in TPI (tune port injection) engines found in some camaros and corvettes in the late 80s. The purpose was to keep the TB from freezing in extreme cold conditions. It was considered by most people to be a pointless addition. Many people choose to bypass the throttle body, but dynos prove that thisit really doesnt help performance at all to bypass it, because the air is moving through the throttle body too quickly to heat the air. Personally, I would leave it alone if you live in a cold climate.
Have you even opened the hood? The injectors are are about 14" downstream of the throttle body. I'm not trying to be a jerk but that is a worse assumption (actually, assertion) than what got this whole thing started.
#40
