Lowered My Car...
Lowered My Car...
...and the ride height stayed the same.
The rear went down just like its suppose to, but the front with no wedge at all didnt do down any. I removed 1/2"-5/8" of rubber and the bitch didnt move....im at a loss.
oh and when i was done with the install and lowering the car back to the ground the jack slipped and luckily the oilpan broke the fall.
Just Not My Day...
Just Not My Day...
sorry to hear that.
hello crv3tt3,
sorry to hear your frustration, i know i would be quite annoyed if that happened to me after all that time/effort of pulling the dam spring out no results,gees i would be wild...
apparently you can also remove the rubber mounts on each end of the spring also to give some more lowering.
i think you have to carefully remove them by cutting them away with some sort of knife/grinder ever so carefully!!!!!
but thats just what i heard though.
give that a try and if still no good,coil over suspsension is your next best thing and you will definately get 2 " -3 " of lowering out them for sure with a doubt.
regards
shae
regards
shae
i hope it settles!
and who woulda thought a l98 oilpan was $300
Ecklers - $300
GM parts direct - $200
Canton - $175
Racepages - $110
Used on ebay - $75
i just cant catch a break
Ecklers - $300
Canton - $175
Racepages - $110
Used on ebay - $75
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Are your front bushings shot? My car barely dropped after lowering. The control arm bushings were completely siezed up and wouldn't rotate.
Putting poly bushings in allowed the suspension to unbind and drop more.
How did you damage the oil pan? Where are you jacking the car from? The oil pan shouldn't be anywhere near the ground, or the jack.
Oil pan sounds like a salvage yard / ebay item to me. Cheapest new one would probably be Chris May at Superior Chevy in kansas, ask for forum discount.
I've had good luck with dino's corvette salvage in Mississippi.
i was jacking from the center cross section of the frame just in front of the oil pan. the rubber on the top of the jack jumped off and down she went.
and the bushings look to be fine.
Received 3,043 Likes
St. Jude Donor '05
Last time I called Superior Chevy Chris wasnt there anymore???
i have seen an l98 vette pan before but can't remember off the top of my head if its the same as the LTx pan but if it is similar then the fbody/truck pan is different along with the oil pump pickup. so i am pretty sure you are going to have to get the ebay one.. they aren't hard to replace with the engine still in the car..
