Superram / Throttle Body Question
It looks like the SR plenum is ported for a 58mm TB. Will my 52mm TB be adequate or should I go with a 58mm? I've got heads, cam, headers, exhaust on my stock cube 86 L98.
Also, if I just need the SR runner to base gaskets, do I need to purchase a full Accel set of gaskets or can I just purchase the base - runner gaskets somewhere?
Received 1,400 Likes
52mm is more than adequate.
If you mean the base-to-heads gasket or runners-to-base gasket, I dont see why you wouldnt just order a set that fits any TPI car. They were sold separately last time I looked.
