Slight stumble at about 2100rpm
Cruising
I need a little input.........I'm a carburetor and points ignition sort of guy, just starting to learn about the computer, fuel injection and hidden behind the water pump distributor. My motor is stock with a 6 speed tranny. It seems to have a slight uneven idle and when I start going through the gears, it's got a real slight but noticeable stumble (just momentary) when I come up to about 2100rpm, then goes away. It only occurs at that point in the rev. I've recently replaced the "distributor". Like I say, I'm JUST starting to learn these motors and the new technology so anybody got any help. Would I look in timing, injection system or what?
Welcome to the "Problems @ 2000 RPM" Club
http://forums.corvetteforum.com/show....php?t=1711949
If you find your problem let me know. I've been trying for 6 months
Charley, Please fill in your profile so we all know what year of car and engine it is, it will help, lots of variations.
Just for starters, get yourself a fuel pressure gauge to connect to the fuel rail. A fuel pressure check is a good start to troubleshooting these problems. And you will always use that gauge, it takes the guess work out of it.
