Flowmaster Y Pipe
Old 06-12-2007, 09:43 AM
murraydeluxxxe
murraydeluxxxe's Avatar
Default Flowmaster Y Pipe
I'm going to put on some new Flowmaster mufflers, and I want to know if it's worth getting the Flowmaster Y pipe with "mandrel-bent tubing...that allows for superior exhaust gas flow". Or if the factory Y pipe is just fine.
Old 06-12-2007, 10:04 AM
Aardwolf
Aardwolf's Avatar
Probably not much gain with just that. For what year? On my year I would use it along with a new front Y without the precats and a high flow main cat. This would make for a decent system and gains.
Old 06-12-2007, 10:47 AM
_twisted_
_twisted_'s Avatar
if this is for a L98, the rear flowmaster is the same size as stock -if yours is in good shape leave it, unless you booger up the slip joint removing the old mufflers
To Flowmaster Y Pipe
Quick Reply: Flowmaster Y Pipe
