Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-23-2007, 01:02 PM   #1
mn_vette
CF Senior Member
mn_vette's Avatar
Default LT1 Mini Starter
I have been doing some exhaust mods to my car and need to find a smaller starter that is a bit more out of the way. I have seen tons of posts for L98 mini starters, but what about the LT1? Has anybody here used a mini starter on their LT1? Who makes them?
mn_vette is offline   Reply With Quote
Old 05-23-2007, 01:18 PM   #2
kalister1
CF Senior Member
kalister1's Avatar
My 93 LT-1 came with a Mini Starter from GM.
kalister1 is offline   Reply With Quote
Old 05-23-2007, 01:52 PM   #3
comp
CF Senior Member
comp's Avatar
are they the same bolt pattern
comp is offline   Reply With Quote
Old 05-23-2007, 05:00 PM   #4
mn_vette
CF Senior Member
mn_vette's Avatar
If they are the same then what do you guys think about these starters?? They are both clockable so that should give me the most room I guess.
http://www.gmpartsdirect.com/results.cfm P/N: 12361146
or
http://cgi.ebay.com/ebaymotors/Proco...QQcmdZViewItem
Old 05-23-2007, 05:38 PM   #5
gslotman
CF Senior Member
gslotman's Avatar
clocking and 153 all good for LT-x..............anybody have the actual weight of stock factory LT-x starter ?
gslotman is offline   Reply With Quote
Old 05-23-2007, 06:10 PM   #6
sami85L98
CF Senior Member
sami85L98's Avatar
I bought a used LT1 94 vette mini starter from ebay and installed on my L98 85 vette, without any problem, i even dont have to shim it nor have to use longer cable to reach battery, mini starter came with stock LT1 cable too, did not use, dont have to.
It was pretty bolt on, for some reason others have lot a dificulty though. Good luck. sami
sami85L98 is offline   Reply With Quote
Old 05-23-2007, 06:11 PM   #7
sami85L98
CF Senior Member
sami85L98's Avatar
I even use stock 85 vette bolts too.
Old 05-24-2007, 12:19 AM   #8
vader86
CF Senior Member
vader86's Avatar
The starter it has is already pretty small
vader86 is offline   Reply With Quote
Old 05-24-2007, 12:27 AM   #9
CentralCoaster
CF Senior Member
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Quote:
That's funny, since I put a LT1 ministarter on my 85 and had to grind the casing down to clear the webbing between the 3 starter bolt holes.
Are you sure you didn't have a 88-91 mini starter?
To the OP, the LT1 starter is basically the same as the 88-91 starter, but is clocked differently so it tucks up higher, for about 1" more clearance where it counts most.
Click the image to open in full size.
CentralCoaster is offline   Reply With Quote
Old 05-24-2007, 09:13 AM   #10
mn_vette
CF Senior Member
mn_vette's Avatar
Good Pics,
You see the long bolts on the LT1 starter that holds the motor thing together? Those ears that stick out that have the bolts go through them are getting in the way of my new exhaust.
I was hoping that someone knew of a starter that had more clearance at that spot. Please let me know if anyone knows of a starter that I could use.
Old 05-24-2007, 10:58 AM   #11
sami85L98
CF Senior Member
sami85L98's Avatar
CC: nice pic's. the guy sold me on ebay said its from 94 LT1, but actually my mini starter wa like 88-91, now i know the diff in 88-91 and LT1's. Huh nice catch and learned something from it, u da man.
Reload this Page LT1 Mini Starter
Tags
91, lt1, mini, starter
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
What starter to buy for my 86... darkman5001 C4 Tech/Performance 12 04-22-2004 08:22 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
