6 point roll cage in 88
I had promised some people here photos of the welded in 6 point we put in the Bonneville car. Took me some time - the cage was in for a while - but i couldn't figure out how to post images.
From the passenger side - notice the handle we put in to assist exits. Improved exit from 17 seconds to 11 seconds!
From the pass side - Notice beside the traditional Petty bar - we added a similar one on the drivers side - to increase headclearance in case of rollover (more support = no crushdown!
From the drivers side: notice the 2 vertical support bars. originally the seat had 2 earflap stle head supports. They were flimsy and caused exit problems - so we took em off and put in bars to limit horizontal movement of the head (turns out to be a big killer)
From the rear: You can see the hoop construction and the support bars coming down. we cut through the plastic and welded them to the frame - using 4"X6" X 1/4" pads (all feet were anchored in the same way.
Basic design was done by Dave Cooper - formerly Rd Racing - Improvements/ additions done at the suggestion of experienced Bonneville salt Flats racers! All pipes (1.75" DOM) bent using Pneumatic mandrel bender and the bendit computer program.
Carl Johansson
Carl Johansson
Carl
Yes, this is the same concept I was thinking.
Does the plate connect to the frame under the door sills?
Carl
You don't have alot of room inside the car to start with - using a design made to fit several cars and several different organizations - well it didn't work for me.
So I bit the bullet - bought a mandrel bender - and went to work!
carl
Um, if you don't mind answering " How much did the bender cost?"
and of course: "Have you thought about making a C4 kit?"
(by kit I mean all the bent tubes, unwelded.)
Awesome job on the cage by the way!
-Merrick
