Lift NOT lower a C4
Lift NOT lower a C4
I have plenty of articles on people lowering their C4 Corvettes. I have a 1991 Corvette that I would like to lift up an inch & a half (due to deep dips in driveways & roads near here). Any suggestions about the best way to do this before I just jump into it, & discover later that there was something that I missed.
Thanks!
Thanks!
Add some leafs in the back and put some 33's on that b**ch!!
Seriously though, I dont know of any way to raise it other than to buy tires with more sidewall. I wouldnt put too much, though. You dont want the tires to hit the fender wall when you hit a bump. A question though, why dont you just try taking the dips and everything at hard angles? There are plenty of dips around here and I just make everyone wait for me to take them slowly and if they say anything, I just reply "I have a Corvette, so SHUT UP!!" Good Luck!!
Matt
Matt
Why
I have a Stalker front end, which sticks out farther. I cannot hit the driveway at a good enough angle to clear the gate. It's almost a straight shot. The rear is simple to lift. I'm think about adding some aluminum spacers to the front spring retainer mounts & fabbing up some longer retaining brackets to start off with. I know that the earlier C4s used a 1/4" aluminum spacer there. I just thought I'd post a quick thread to see if anyone else had done a small C4 lift. There always seems to be one little thing that you don't calculate for (such as needing longer bolts as an example).
I would strongly advise against this..
if it were my car these would be my options:
1: remove stalker front end and install back to stock
2: move
3. sell corvette and butcher a camaro, impala SS or something else
2: move
No Thanks
No thanks. This car is nowhere near stock, & I don't want it to be. The motor now uses a carb, so the hood has a molded C6 Z06 Viper-style hood scoop for the needed clearance. Flip-up headlights are gone. Front running lights are brighter than stock headlights. A steel bumper has been welded on, & the Stalker front bumper covers it up. It also allows more air to come in where the radiator shroud has been modified. The mods have to stay. The front end is going up at least an inch. Thanks for the input, though. If it must be lifted with rims & tires, then some 18s with a taller overall tire hight will be used, but I don't plan on it, since I love the Sawblade 17x11 Zr1 rims I have in the rear!
Its your car that is being destoryed not theres. I know all the rednecks here jack up there trucks where a ladder is needed to get in there and some loud exaust acting like total terds but your bringing the vette to a new "low". Eww. I agree on taking the front stalker off**I was considering getting one of those bumpers from midamerica in the future but this thread just changed my mind** and going back to stock.
I wonder if your car already has a lowering kit... it might be worth checking that.
also, new springs will bring it up.
the best bet would be coil over shocks, that you can control the ride height.
Ride Height
Do you have room for a slightly taller tire? The reason i am asking is because if you raise the body you will increase the space in your fenders and hood. I am not sure it is going to look very good. If you can clear a slightly taller tire you will fill the fenders more and it should look better. I am not sure this will entirely solve your situation but I am trying to offer an alternative.
Coconut, My question to you would be this; Your driveway, it has a gutterpan in between the pavement and the driveway correct? If so, you SHOULD be able to get a 2 inch metal pipe about as wide as the driveway, and make a concrete ramp leading up to the driveway with the pipe in the middle for water drainage. I cant help with the other ditches or dips or whatever. Good Luck!!
Matt
Area
I think a taller tire/wheel combination would still look ok and raise the car. Like maybe a 275/40R18. That would give you 1/2" lift, but of course would be expensive.
I haven't seen many taller 17" tires, but I think Nitto makes a 275/50R17 tire in one of their product lines, but its probably geared more towards lowered SUVs than raised corvettes.
Matt
Big Chief Nitrous Engine
Not Mine
One more thing. This is not my driveway I use often. If I could just park on a curb somewhere I would. I'm used to driving low vehicles. I love them. The front bumper is the only Stalker piece I own. I don't care too much for the rest of the package. Even if I put the original bumper cover back on (which no longer fits due to the welded inside steel bumper), the car still needs to be lifted 1" in the front to level it off, so that it also won't hit.
Nitrous Sam
I know I'd love it. That welded aluminum intake looks sweet! I have a 427 Tall Deck that has been punched out to 540 cubes. It is in a full tube chassis 1982 Corvette Collectors Edition that has been narrowed.
Leaning
Maybe I should have said that the front touches, & not "hits." I figured 1/2" will clear, but the extra 1/2" would be good insurance. That's all. Boy, am I glad I posted this thread. I've never received so many negatives. I get the picture guys! I'm leaning towards a taller tire set, & rims if neccessary. I can buy some 335/35/17 tires in the rear, & put my 315/35/17 on the front (They do fit), or something that will match the overall diameter of the 335/35/17 tires. I'm up for all suggestions, but the front end can't be changed at this point. Remember, the stock front also touches. Thanks everyone.
my point was raising the car will hurt its performance and handling characteristics.. I know options 2 and 3 were absurd - I was trying to make a point.. maybe too harsh..
In all seriousness make sure the car hasn;t been lowered already.. stock ride height should work just about anyplace in the USA.. I traverse some tall speeds bumps daily.
