tune up performance questions
Old 04-25-2015, 11:47 AM
dgantt
dgantt's Avatar
Default tune up performance questions
Hey everyone,
Im about to add a new MSD system and tought it would be a good time to ask some qeustions to the vette experts for maybe gaining a few more ponys. I have a 90 speed density and was wondering any advise on timing. Is there any advantage to advancing or retarding the timing on these cars past factory or will the ECM just correct it and end up losing power. Also a few years ago I changer injectors to the Bosh 111 24lb injectors, the car has an adjustable fuel pressure regulator on it. Once again any advantages to uping the fuel pressure? Thanks for all comments!
Old 04-25-2015, 02:44 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Keep the HEI that msd wont give you one ounce of power
Old 04-25-2015, 09:58 PM
Cliff Harris
Cliff Harris's Avatar
The ECM will compensate for changes in fuel pressure, so zero net gain there.
Old 04-25-2015, 10:37 PM
Tom400CFI
Pro Mechanic
Tom400CFI's Avatar
Received 3,181 Likes on 2,322 Posts
The car may 'like" more timing, but you need to "Feed it what it wants". In otherwords, try different timing, then test (objectively). I agree w/cuisinartvette that the MSD won't do squat for power.
Old 04-26-2015, 10:37 AM
dgantt
dgantt's Avatar
OK thanks guys, Im keeping the HEI system but replacing the plug wires and replacement coil for a retune, but I am adding the 6AL because I have heard goodthings about it. So no gains for bumping fuel up, and no body has a sweet spot for the timing. As asways thanks for the responses.
To tune up performance questions
Quick Reply: tune up performance questions
