Torque spec and sequence TPI manifold
Old 05-02-2007, 07:34 PM
bruced267
bruced267's Avatar
Default Torque spec and sequence TPI manifold
Can anyone give me the correct torque spec and sequence for 85 TPI manifold? Any other tips on putting this back together would be great.
Old 05-02-2007, 09:16 PM
bruced267
bruced267's Avatar
CFI EFI can you crack open that book of yours and help me out?
Old 05-02-2007, 09:24 PM
John A. Marker
John A. Marker's Avatar
Front of block REAR
2 1 3 4 5 6
Above is intake manifold bolt tightening sequence for the 1985 thru 1991 - tighten to 35 pounds.
Old 05-02-2007, 09:34 PM
bruced267
bruced267's Avatar
John Thanks for the torque spec but if Im reading the sequence right you have me tightening one then the other, did I miss something? Thanks Bruce
Old 05-02-2007, 09:47 PM
John A. Marker
Tighten bolts 1 thru 12 as listed above. Tighten the intake to about 10 pounds following the order above, drivers side then passangers side. Up poundage to 15 and tighten again. Continue to increase and tighten in the order until you reach 35 pounds.
On my older chevy, you start in the center on the drivers side and tighten two then go to the passangers side and tighten the center two. Back to drivers and tighten one on each side of the two you just tighten and continue until finished. That would spread the gasket from the center out. Corvettes are DIFFERENT
-John
Old 05-02-2007, 09:53 PM
bruced267
bruced267's Avatar
Your Kidding Right?? If I did Middle out, alternating sides would this cause an intake leak?
Old 05-02-2007, 10:00 PM
John A. Marker
The 85 thru 91 bolts are tighten on one side then the other per Chevy spec. If you look at the sequence, it is kind of start at one end less one, reverse one and then continue to rear of block. The go to the other side.
If you did center out and alternate side, it would probably work. BUT you asked for the sequence per the book which is what I gave you above.
If I can get to my scanner I can probably scan the picture from the book. It isn't too great, a box to represent the engine and then the numbers like I gave you above and a label for front and rear of engine.
Old 05-02-2007, 10:25 PM
CentralCoaster
CentralCoaster's Avatar
Location: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Not kidding, that's how it's written. I had a hard time believing it to. maybe GM is playing a joke on us.
Old 05-03-2007, 08:25 AM
AGENT 86
AGENT 86's Avatar
OOps, the image wasn't clear. I'll try and post again.
Old 05-03-2007, 08:36 AM
AGENT 86
AGENT 86's Avatar
http://members.shaw.ca/agent86/Intake%20Torque.pdf
Old 05-03-2007, 10:10 PM
bruced267
bruced267's Avatar
Agent Thanks for the link! If you zoom in the picture shows a snug sequence, and a torgue sequence. Looks snug is center out, and torque is one side then the other. That makes some sense to me. Is the torque 25 lb snug 45 torque?
Old 05-03-2007, 10:49 PM
AGENT 86
AGENT 86's Avatar
Being as there were cast iron and aluminum heads in 86, I would look for more info. It's been a year since I built my motor so I can't remember. I'll look into later.
Old 05-03-2007, 11:48 PM
AGENT 86
AGENT 86's Avatar
35 lbs in both my books.
To Torque spec and sequence TPI manifold
Quick Reply: Torque spec and sequence TPI manifold
