Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-21-2007, 11:21 AM   #1
byebyeL98
CF Senior Member
St. Jude Donor '10-'11-'12-'13
byebyeL98's Avatar
Default Car battery charging - 10 amp or 2 amp?
What is the difference between using a 2 amp charge vs a 10 amp charge for the battery?
byebyeL98 is offline   Reply With Quote
Old 04-21-2007, 11:48 AM   #2
dzierke
CF Senior Member
About 8 amp's...
If you have a battery that's in good shape but your car sits in storage, give it a 2 amp trickle charge once a month. This will keep your battery from failing when you really need it..
If your battery is weak, charge it over night at 10 amps. Then have it checked.
Most small charger will shut off automatically when the battery is fully charged. Get a charger with auto mode.
dzierke is offline   Reply With Quote
Old 04-21-2007, 12:03 PM   #3
jfb
CF Senior Member
The difference is in the time that it takes to charge up a totally dead battery. NEVER let a lead acid battery totally discharge because each time you do that, the battery loses some of its amp-hour capacity. Also, car batteries self discharge up to 1% each day even disconnected and during discharge, lead sulphate collects on the plates. Left for long (4+wks) periods, the lead sulphate becomes hard and will not convert back to lead and sulphuric acid upon charging. Lead sulphate is an insulator and a fully sulphated battery will not draw current from a charger and is a door stop. Charge your stored battery periodically or get a battery tender which is a , "smart" charger which measures the battery voltage and only charges the battery when its state of charge drops about 10% and then turns off.
jfb is offline   Reply With Quote
Old 04-21-2007, 12:04 PM   #4
snowmaker2000
CF Senior Member
Default 10 amps to Charge, 2 amps to Maintain
Use 10 amps if the battery is completely dead and has sufficient water/acid in it. Make certain you remove the battery caps to reduce the chance of explosion when you remove the charging leads.
Use 2 amps to keep the battery conditioned.
When using the 10 amp, once the charger (if it is late model) detects a full charge condition, it will drop down to 2 amps to maintain the battery.
Once you charge the battery, go to Sears and get a two dollar specific gravity tester. It looks like a eye dropper with colored ***** in it. Use it to check for shorted cells. You suck up acid from each of the six holes in the battery. None of the ***** shoud drop down, if they do, buy a new battery because no amount of charging gonna fix it. A shorted battery will cause you to buy an alternator down the road.
Good luck!
snowmaker2000 is offline   Reply With Quote
Old 04-21-2007, 12:04 PM   #5
Slalom4me
CF Senior Member
Quote:
for the battery?
The rate of charge. Amp is an abbreviation of ampere-hour, a unit of electric charge.
The charge rate should be based on the size or capacity of the battery
to be charged. A 2 amp rate is appropriate for smaller batteries as
used for motorcycles, lawn tractors and so on. 8, 10 & 12 amp rates
are suited for automotive sized batteries.
Faster charge rates than recommended reduce charging time but
lead to increased heat which can warp components or possibly rupture
the battery case. I do not well understand the issue with lower charge
rates but I believe it can be detrimental over the long term.
I'd like to mention the Schumacher SC1200A charger here.
After using a series of fixed output chargers over the years, I switched
to the 1200A. It has performed well and has kept my current ACDelco
battery alive long beyond the time that previous batteries needed
replacement.
The 1200A is one of the chargers that uses a variable voltage charging
approach. Initial charge voltage is relatively high, then it tapers back
as charge level increase, finally charging shuts off. This charger also
offers settings for lead-acid, glass-matt (AGM), gel cell and deep-cycle
batteries. This lets me use it on the ACDelco, on a Yellow-Top Optima
and on some instrument gel-cells I have.
Slalom4me is offline   Reply With Quote
Old 04-21-2007, 12:15 PM   #6
Slalom4me
CF Senior Member
Quote:
Originally Posted by Slalom4me View Post
I do not well understand the issue with lower charge rates
Sulfation - the same issue that occurs when batteries are left uncharged.
From Crown Battery
Undercharging
Undercharging a battery, even to a small degree, if continued, leads to
excessive “sulfation”. The same is true of batteries which have been
left standing in an undercharged state for an extended period. High
temperatures rapidly accelerate sulfation when batteries are left
standing in a partially charged condition. The cells of a sulfated battery
will give low specific gravity and open circuit voltage readings. On
charge, voltage readings will be unusually high. The battery will not
become fully charged after a single normal charging when sulfation has
taken place over a prolonged period.
Old 04-21-2007, 12:22 PM   #7
byebyeL98
CF Senior Member
byebyeL98's Avatar
Great information - thanks for helping me to understand!
Old 04-21-2007, 03:11 PM   #8
GGTOOLS
CF Senior Member
the slower you can charge the battery the better...for the battery
GGTOOLS is offline   Reply With Quote
Old 04-22-2007, 09:04 AM   #9
metal tech
CF Senior Member
I'll throw my recent experience in for you to ponder. I just bought 2 battery chargers, A Vector and a CTEK. Both of these have the "Recondition" mode that can reverse the sulfation condition. It is like a 24+ hr process but it does work, saved one of my Optima D31 Yellow tops. I used the 2amp charge to prevent heat buildup on the optimas, heat boils the liquid/gell inside and kills them since you cannot add water. The complete process took 4 days, and the battery never got hot. Like Slalom4me mentioned the Schumacher charger, the newer Microprocessor controlled chargers are worth it, less risk of battery overheating and possible explosion. Al
metal tech is offline   Reply With Quote
Reload this Page Car battery charging - 10 amp or 2 amp?
Tags
10, 10amp, 2006, 2amp, amp, amps, battery, car, charge, charging, corvette, dead, diference, difference, totally
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Weights, measurements, ratios, strengths, etc leaftye C5 Tech 252 02-02-2014 12:23 PM
C6 FAQ (Frequently Asked Questions) docrings1 C6 Corvette General Discussion 216 12-01-2010 03:33 AM
Now What?? Starter won't crank.. danno12345 C3 Tech/Performance 9 05-19-2005 02:06 AM
New battery and car won't start up after 2 weeks of sitting. 87vette C4 Tech/Performance 11 05-09-2003 09:35 AM
Response for "Why Pyramid Amps are so cheap" AJC5 Audio/Electronics 65 12-11-2002 11:00 AM
Trivia Time! Urban/Rural Legends re Battery Storage on Concrete Floors... paul 74 C3 Tech/Performance 21 11-03-2002 05:38 PM
[Electrical]: Continuity between ground and hot it appears. scorp508 C4 Tech/Performance 68 10-05-2002 01:44 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
