Go Back   Corvette Forum > C4 Corvettes, 1984 - 1996 > C4 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C4 Tech/Performance
L98 Corvette and LT1 Corvette Technical Info, Internal Engine, External Engine Sponsored by
J&D Corvette
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-06-2007, 09:07 AM   #1
topspin
Junior Member
topspin's Avatar
Default 96 LT-1 Crank Sensor
Will a bad crank sensor stop the ignition coil from firing on a 96 LT-1 ?
topspin is offline   Reply With Quote
Old 04-06-2007, 10:20 AM   #2
Casethecorvetteman
CF Senior Member
Casethecorvetteman's Avatar
Send a message via MSN to Casethecorvetteman Send a message via Yahoo to Casethecorvetteman Send a message via Skype™ to Casethecorvetteman
I believe so. Its an optical sensor. If its failed it shouldve set a DTC.
Casethecorvetteman is offline   Reply With Quote
Old 04-06-2007, 10:41 AM   #3
Tom Piper
CF Senior Member
Tom Piper's Avatar
It is my impression that the '96 crank sensor is only for cylinder missfire detection.
If I am correct, it has nothing to do with ignition control.
The optical sensors in the Opti-Spark control the ignition.
Tom Piper
Tom Piper is offline   Reply With Quote
Old 04-06-2007, 07:04 PM   #4
BAM92
CF Senior Member
BAM92's Avatar
It will stop you dead in your tracks. Been there on my 96 LT1 Trans Am.
BAM92 is offline   Reply With Quote
Old 04-07-2007, 12:13 AM   #5
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
Tom Piper
It references between the cam and crank for OBDII misfire ...
The opti sends the signal to the coil...
I have run with the crank sensor disconnected...
Mo
__________________
1996 Black Coupe, Electric
Netgain 2-Siamese 9" electric motors
Zilla HV 2K controller
244v 200ah GBS Batteries
Powerglide 2 speed
QA1 Coil Overs
Manzanita Micro PFC 40 Battery Charger
Over 100 miles range at 65 mph
www.ndneyes.com/for electric
www.ndneyes.com/mo for non electric
Mo_Bandy is offline   Reply With Quote
Old 04-07-2007, 01:57 AM   #6
96GS#007
96GS#007's Avatar
Mo
On the '96, the crank sensor is for OBD II compliance only. It's used to detect misfiire. I ran mine with a bad one for a couple weeks until I had a chance to replace it.
One minor correction to Mo...It looks at the acceleration and deceleration of the crankshaft to determine misfire, it doesn't bother with the cam at all. That's why the reluctor ring is on the front of the '96 crank
__________________
Jim
'96 Grand Sport #007
A few mods here and there
96GS#007 is online now   Reply With Quote
Old 04-07-2007, 03:34 AM   #7
BAM92
CF Senior Member
BAM92's Avatar
Quote:
Hmm, that it was the dealer told me back when it died and had it towed to them under warranty. Never looked into it further. Shows you can't trust the dealer.
Old 04-08-2007, 01:11 AM   #8
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
You're right Jim... thanks for the correction I was thinking of something else ... I'm an old froggie LOL
Cheers!
Mo
Old 04-08-2007, 09:26 AM   #9
Desert1957
CF Senior Member
Desert1957's Avatar
Default sensor
I had a 93 LT1 that would run great when cold and in "Open Loop" soon as the engine went closed loop it hardly ran sputterring and backfiring , the fix was a bad "Crankshaft Position Sensor"
Was a Warranty problem Vette had 4000 miles on it , took the Dealer 2 weeks to fix it. here is a list of what they replaced over the 2 week period. remmember WARRANTY repair
Spark Plugs
Spark Plug Wires
Complete "Opti-Sspark Distributor"
ECM (3 times)
Fuel Filter
Fuel Pump
Injectors
and the final fix was "Crankshaft position Sensor"
Desert
Desert1957 is offline   Reply With Quote
Old 04-08-2007, 09:45 AM   #10
Casethecorvetteman
CF Senior Member
Quote:
Originally Posted by Desert1957 View Post
ECM (3 times).....
3 frigen times?? What a bunch of useless barstards eh? I bet youre glad you found out how incompetent they are while it was still under warranty and at their expense!!!!
Old 04-08-2007, 11:12 AM   #11
Tom Piper
CF Senior Member
Tom Piper's Avatar
I think there are some mis-communications here.
On a C4, only a '96 has what I am calling a "Crankshaft Position Sensor."
As far as I know, the manual calls it a "Crankshaft Position Sensor."
It's only purpose on a '96 is for cylinder missfire detection.
No C4 before a '96 has this sensor.
It is located on the bottom of the timing cover and the only timing cover that has the place for it is on a '96 timing cover.
It has nothing to do with the Opti-Spark.
Since the originator of this thread specifically stated a '96, I am assuming it is this '96 only sensor.
The Opti-Spark has low and high-res pulses.
These pulses are detected by the ECM/PCM for what some call cam and crankshaft postion to control spark and injection timing.
All LT1 and LT4 engines have these pulses generated in the Opti-Spark.
On a stock engine, if the low-res from the Opti-Spark is completely missing, the engine will not run.
On a stock engine, if the low-res pulse is OK and the high-res pulse is missing, the engine will run at reduced performance.
I'm told that an engine with the Delteq requres both low and high res pulse to run at all -- and logic tells me the LTCC is probably the same.
Tom Piper
Old 04-08-2007, 09:30 PM   #12
96GS#007
96GS#007's Avatar
Tom Piper
Tom is correct on all counts.
__________________
Jim
Old 04-09-2007, 06:46 AM   #13
Desert1957
CF Senior Member
Desert1957's Avatar
Default Tom please help me to understand ?
Tom Piper
I did have this problem I listed in an early posting here , The Dealer did replace what they called a "Crankshaft Postion Sensor" on my 93 and it did effect the way the engine ran during closed loop , here is the gm part# 10457661
I did a seach on GMparts for less web link and Parts America , they all list this part for a 1993 LT1
Click the image to open in full size.
So I guess I am questioning your quote "No LT1 engine before 96 has this sensor" help me to understand what I am missing , thanks Desert
Old 04-09-2007, 08:33 AM   #14
Tom Piper
CF Senior Member
Tom Piper's Avatar
Since I have a '92 LT1, I don't have the Crankshaft Position Sensor that I am referring to.
So, I will have to let someone with a '96 confirm if that is a Crankshaft Postion Sensor.
What I can tell you is I converted my '92 non-vacuum vented Opti-Spark to a '95 style vented Opti-Spark.
And, part of that conversion was I had to change to the '95 style timing cover.
Since my '92 is OBD-I instead of OBD-II, I had to make sure I got a '95 timing cover (without the place for the Crankshaft Position Sensor) instead of a '96 timing cover (with the place for the Crankshaft Postion Sensor) because there was no need for the Crankshaft Position Sensor with my OBD-I.
Read this link:
http://para.noid.org/~muttvette/opti.html
As you can see, the third timing cover down for a '96 and '97 (F-body) has the Crankshaft postion sensor.
If the sensor you mention is really a '96 style Crankshaft Postion Sensor and it is on your '93, I would like to know how it got there.
Tom Piper
Old 04-09-2007, 10:30 AM   #15
96GS#007
96GS#007's Avatar
Hope they paid for that and not you because it's clear the dealer is making sh*t up if that's what they put on the invoice. The pic is not a pic of a CPS. No LT1/4 before '96 had a CPS, period.
GM Parts Direct lists the part as:
GM PART # 10457661
CATEGORY: Chassis Wiring & Computer Controls
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $30.28
OUR PRICE: $15.75
DESCRIPTION: SENSOR AS
The key descriptors are "Chassis Wiring...." and "Sensor AS" and specifically the one letter they omitted in the latter..."B" as in ABS. It's a rear ABS sensor.
__________________
Jim
Old 04-09-2007, 11:50 AM   #16
Desert1957
CF Senior Member
Desert1957's Avatar
Default Please step off
I'm not saying you guys are wrong. I was just relaying an experience I had with my 93 as stated in an earlier posting.
I do not have the 93 anymore or the Dealer Warranty Invoice for the repair.It went with the car.
Did do a parts search and found a listing for a "Crank Position Sensor" listed for a 1993 5.7 LT1 corvette on "PartsAmerica" it listed the following OE# on the page with a pic #10457661
http://www.partsamerica.com/ProductL...osition+Sensor
Here is the other link you think I'm Lying about from "GMparts4less"
I'm just trying to figure out who is right , not saying you guys are wrong
Desert
Old 04-09-2007, 02:21 PM   #17
topspin
Junior Member
topspin's Avatar
My car ran great for about 15 minutes then it would always shut down. I replaced the ignition module and the ignition coil and car did the same thing only after fooling with it now I noticed the Tach has no reading. This is why I thought maybe the Crank P Sensor could have something to do with this problem. Now I cannot even get the Ignition Coil to fire. My readings are good on the ignition module connector with volt meter except I checked the ground on the black/white wire with key in the On position and it still showed grounded and I beleive it is not suppose to be grounded when the key is on.
Old 04-09-2007, 07:14 PM   #18
96GS#007
96GS#007's Avatar
Desert
The LT5 in the ZR1 had a crankshaft position sensor. The LT1 (prior to '96 did not).
__________________
Jim
Old 04-10-2007, 12:49 AM   #19
Vis Croceus
CF Senior Member
Vis Croceus's Avatar
There was no CPS from the factory on any LT1 prior to 96. Read any of the LT1 books or any of the myriad websites describing LT1 changes over the years.
Let's say for a second that your 93 did have a CPS. How is your information on how the CPS caused problems for you in closed loop (which in itself is ridiculous - CPS doesn't care about open vs. closed loop) relevant to the OP's question of whether a CPS on a 96 will prevent the coil from firing?
Since you don't own the car in question any more, and your posts are irrelevant to the OPs question, you seem to be just a :
Vis Croceus is offline   Reply With Quote
Old 04-10-2007, 01:25 AM   #20
Mo_Bandy
CF Senior Member
Mo_Bandy's Avatar
I'll say it again... I have a 96, I can unplug the CPS it will not keep the engine from running, it will set a code...
But it will run fine (unless you have the timing off a tooth).
It only is there for OBDII for detecting misfires....
If you updated to a later model timing cover they did not have the cps sensor unnless it was at least a 96. If this is the case where is the harness to you connected the CPS too?
I'm with Tom Piper and 96GS007 on this one...
MO
__________________
Powerglide 2 speed
QA1 Coil Overs
Reload this Page 96 LT-1 Crank Sensor
Tags
affect, bad, converter, corvette, crank, crankshaft, location, lt1, open, opti, position, replacement, sensor, signal, torque
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
