Adapting C5 wheels to a C4
Ok I tried to make sense out of a few threads on this issue and just got more confused with some of the conflicting info out there...
I have an opportunity to pick up a set of C5 wheels for $500 from a friend near where I live but neither he or I are sure what adapters are needed if necessary. They are supposed to be the stock original wheels on his C5.
Here is what he has:
17x 9.5 fronts
18 x10 rears
54mm offset
I plan to do the C5 brake upgrade using WDO-MKR's brackets if that makes any difference.
17x 9.5 fronts
18 x10 rears
54mm offset
Received 1,404 Likes
For an 85 you'll need adapters.
17x 9.5 fronts
18 x10 rears
54mm offset
17x 9.5 fronts
18 x10 rears
54mm offset
C5 OEM are 17x8.5 +56 / 18x9.5 +63
C5 Z06 OEM are 17x9.5 +54 / 18x10.5 +58
You can get replicas in the correct offset for your car for $500-600. Cheaper than the used wheels+adapters.
I've got a brand new set of C6 rims, 18's and 19's and they are fresh off a 2006 not Copies but geniune. $400.00 plus shipping. I have them posted in the C6 FS section.
If they would fit I might be interested depending on what shipping would cost me too. Just let me know when you have pics up...
