Torque specs on rocker arm studs
Old 10-11-2001, 09:29 AM
95Aqua
95Aqua's Avatar
Default Torque specs on rocker arm studs
Anybody know off the top of their head what the torque spec is for the rocker arm studs on the LT1. I'm putting 1.6 RR with 7/16 studs, but I can't find anywhere what to torque them to and I want to be carefull with these aluminum heads.
Old 10-11-2001, 09:35 AM
ralph
ralph's Avatar
Default Re: Torque specs on rocker arm studs (95Aqua)
i torque mine to 65ftlbs.
Old 10-11-2001, 09:39 AM
95Aqua
95Aqua's Avatar
Oh one other thing, do you use anti-sieze?
Old 10-11-2001, 09:44 AM
65Z01
65Z01's Avatar
Cruise-In II Veteran
My L98 heads had steel inserts in the rocker stud holes so anti-sieze wasn't required.
Old 10-11-2001, 12:28 PM
ralph
ralph's Avatar
i actually used red locktite. I was getting tired of them loosening up when i adjusted the valves.
Old 10-11-2001, 07:24 PM
95-383's Avatar
The spec for the rocker studs is 50 ft lbs. I use sealer on the threads.
Old 10-12-2001, 12:20 AM
h rocks
h rocks's Avatar
Default Re: Torque specs on rocker arm studs (95-383)
50 lbs/ft is it, and I second the motion on the Teflon sealer.
BTW, I posted this question on another thread: What other white sealer might work? I have seen *many* different white Teflon sealants at Home Depot, Lowes etc..
Old 10-12-2001, 07:01 PM
ralph
ralph's Avatar
Default Re: Torque specs on rocker arm studs (h rocks)
i guess the AFRs are differnt than the stock heads. No sealer needed on the AFRs
To Torque specs on rocker arm studs
Quick Reply: Torque specs on rocker arm studs
